Suspension Help! Weird vibration after lowering springs installed.
Old May 27, 2010 | 09:59 PM
calisao80's Avatar
calisao80
I just installed H & R springs on Friday. Now i feel a weird vibration in the front of the car from 1500 to 2500 rpm. I haven't done an alignment yet, but I don't think that's the problem. Any advise would be helpful.
2010 mini s
Old May 27, 2010 | 10:50 PM
traction's Avatar
traction
probably cv joints. mine does it too.
Old May 28, 2010 | 03:30 AM
tvrgeek's Avatar
tvrgeek
Brand new and CV's vibration? Is there a geometry problem here?
Old May 30, 2010 | 08:39 AM
slinger688's Avatar
slinger688
I think you need the alignment first.
Old May 30, 2010 | 12:11 PM
YourBoyRay's Avatar
YourBoyRay
I just bought the H&R Sport Springs through Alta and wanted to install them this coming weekend. So you have to get an alignment done first before installing these? Also, through who should i get the alignment done (please anyone suggestion except the Mini dealers)?
Old May 30, 2010 | 12:29 PM
iwashmycar's Avatar
iwashmycar
NO, after theyre in.
Mine has the vibration too... ive put about twenty-some thousand on them and its still there lol
Old May 30, 2010 | 12:40 PM
YourBoyRay's Avatar
YourBoyRay
Is it a strong vibration? I don't want my Mini shaking like crazy as I motor about town.
Also, did you do the alignment after the springs installed?
Old May 30, 2010 | 05:10 PM
slinger688's Avatar
slinger688
OP needs an alignment after the springs install. Do this before changing the CVs.
Old May 30, 2010 | 05:41 PM
iwashmycar's Avatar
iwashmycar
not really, just while accellerating in second gear. almost feels like an off-balanced wheel, though ive had many different wheels on there lol
i got it aligned after the install, yes
its hit or miss... seems to just depend on the car from what ive read
Old May 30, 2010 | 09:53 PM
YourBoyRay's Avatar
YourBoyRay
thank you iwashmycar (your screen name makes me laugh like crazy eveytime i look at it).
I'll get an alignment done as soon as installed too, it due regardless so I might as well mod it now and then align it, kills two bird with one Mini.
Old May 31, 2010 | 03:05 AM
cmcveay's Avatar
cmcveay
I had the same thing when I lowered mine. It had about 7k on it at the time. The 4 wheel alignment helped a little and now, it's got about 17k on it and I hardly notice it. From what I've seen in previous posts on the issue, it's because of the change in angle on the driveline. There are lots of 20, 30 and 50k plus lowered MINI's out there still running strong though.
Old May 31, 2010 | 05:27 AM
tvrgeek's Avatar
tvrgeek
I still am quite concerned that lowering an inch and a half is causing CV joint vibration issues. The very concept of a CV is... ready for this? CONSTANT velocity. Of course the are not, but just much better than a universal joint. If you get vibration at half the intended travel, there is something very wrong. Design wise.
Lets throw some theories out there:
#1 Phasing issue: Even CV joints should be in phase. Each ball should be lined up with the corresponding ball in the other end, just like a universal. The more ***** in the CV, the less sensitive it would be. I wonder if the splines are not keyed, so the amount of offset between a ball on the inner race and a ball on the outer race could vary. That would explain why some cars are worse than others. This would be an assembly procedure that does not matter at stock ride, but needs to be addressed when lowered.
#2 Exceeding permissible operating angle: Is the axle already offset a lot at stock ride height? Then the lowered stance cold be pushing the limits of prudent offset angle. This would have been a design compromise for the very tight packaging. Exaggerated by #1 above.
#3 BMW are morons. I seriously doubt this. But when brainstorming, one should always post all possible solutions.
Old May 31, 2010 | 06:26 AM
iwashmycar's Avatar
iwashmycar
^^^ #2 sounds most likely, and maybe there could be slight differences in clearances from car to car!??... I cant comprehend why it only affects 'some'
Ill be upgrading to coils soon so ill be able to see if anything differs especially at different angles. i want to go lower... gonna be pissed if it gets worse lol (seems likely)
Old May 31, 2010 | 07:17 AM
slinger688's Avatar
slinger688
Iwash, I think it is not wise to go too low on the coils, especially if you track the car.
Old May 31, 2010 | 07:23 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Actually the MINI has a pretty nice axle angle and it takes a lot of lowering before the axle angle becomes as extreme as most other lowered cars. If you lower the car 1" or 1.5" like most springs and look under the car you'll see the axle angle is hardly outside the operating angle of the CV...especially when it's just sitting there uncompressed (i.e. not hitting a bump)
My car is lowered 6 inches, no vibrations (knock on wood) I'm still baffled by this since it seems to only be some cars and there's no noticeable pattern.
Old May 31, 2010 | 07:25 AM
slinger688's Avatar
slinger688
Do you have a pic of the angle, stock versus lowered? Thanks.
Old May 31, 2010 | 08:00 AM
iwashmycar's Avatar
iwashmycar
oh i know.. its probably also not wise to get VMaxx's either, especially if the car is tracked, but theres a good chance it wont be, as much as id like to lol...
just need another inch or so!
Old May 31, 2010 | 08:06 AM
Rally@StanceDesign
I don't, sorry.
Old May 31, 2010 | 10:19 PM
calisao80's Avatar
calisao80
Thanks for the help. Ill get the alignment done after I break in the springs. If the vibration continues I may take them off.
Old May 31, 2010 | 10:23 PM
calisao80's Avatar
calisao80
thanks
Old May 31, 2010 | 10:33 PM
KevinC's Avatar
KevinC
I have this EXACT issue, first I've seen of others having it. My car is on an H&R Touring Cup Kit. Aligned after installation, no other issues (other than that I wish the kit were a bit more aggressive, but I digress). Alignment is definitely not the problem in my case. I've suspected something CV-related all along, but exactly what?
Old Jun 1, 2010 | 12:37 PM
tvrgeek's Avatar
tvrgeek
Kevin, have you looked at the CV phasing? How many ***** does the CV have?
Old Jun 1, 2010 | 12:40 PM
tvrgeek's Avatar
tvrgeek
How did you lower it 6 inches when there is not that much travel? The rear arms hit the body at about 4 even if it had no stop in the shock. It looks like there is only about 2 1/2 bump at any corner.
Old Jun 1, 2010 | 02:32 PM
Rally@StanceDesign
No, the stock rear arms hit the body at 6" , a little more if you remove the control arm bumpstop.
I'm running (extremely) shortened bilstein struts on all four corners, and custom machined upper mounts front and back to reduce stack height and increase travel. I'm not a fan of the limited travel on our cars in stock form, so I did quite a bit of work to remedy it to my liking.
Old Jun 1, 2010 | 02:34 PM
Rally@StanceDesign
3 on the outside CV.
(Edit: Now that I think about it, maybe I'm thinking of the inners)
