Suspension universal swaybar bracket to fit 22mm sway bar?
Old Mar 28, 2010 | 10:12 PM
rehgee's Avatar
rehgee
can i buy any 7/8 swaybar bracket for my 22mm rear swaybar because i bought the mini madness swaybar used and the guy didnt give me the brackets because he told me the stock ones would fit it, but obviously a 16mm bushing bracket would not fit my new 22mm bushing bracket so im upset and wondering if i can just purchase a 7/8 bracket from ebay, they look universal with the long slots for any placement for the screw
any help would be appreciated!
thank you for your time
Reggie
Old Mar 30, 2010 | 10:03 PM
BLU-BY-U's Avatar
BLU-BY-U
be careful with the universal brackets as they can be too big and hit the MINI frame. I tried the Energy Suspension universal greasable bushings, and they are too tall and 2 mm too wide in the span. I think I should have gone with the non-greasable bushings as they seam that much shorter and have a closer span.
Old Mar 30, 2010 | 10:07 PM
rehgee's Avatar
rehgee
What did you end up doing?
Old Mar 31, 2010 | 06:38 AM
BLU-BY-U's Avatar
BLU-BY-U
Well I should have looked for the non-greasable bushings as they should have worked. What I did was take the kit I bought and cut them down to almost the right size and then took the factory metal mount and heated that up to finish a custom bushing. They look fugly, but will do for now until I find a place that sells the non-greasable to make sure they fit. The greasables I found at Advanced Auto Parts.
Old Mar 31, 2010 | 07:33 AM
rehgee's Avatar
rehgee
Oh okay thanks, I think the non greaseable ones are at autozone so thanks!
Old Mar 31, 2010 | 07:42 AM
BLU-BY-U's Avatar
BLU-BY-U
Amazon carries the smaller version that should fit our MINIs.
Amazon Energy Suspension 22 mm 9.5126r
Old Mar 31, 2010 | 07:43 AM
BLU-BY-U's Avatar
BLU-BY-U
Autozone, Checker and Advanced only sell the larger version, the 9.5108, it is too tall and the span is the same as the greasable., you want the one above.
Old Mar 31, 2010 | 07:44 AM
BLU-BY-U's Avatar
BLU-BY-U
See this chart.
http://images.oreillyauto.com/parts/...bushingsng.pdf
Old Mar 31, 2010 | 07:50 AM
BLU-BY-U's Avatar
BLU-BY-U
Or the Prothane bushings at Amazon, they look a little short still.
Amazon Prothane 22 mm bushing
Old Mar 31, 2010 | 03:14 PM
rehgee's Avatar
rehgee
oh thanks
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
