Suspension Clunk after Coilover install
I had BC coilovers installed on my 09 Clubman S. Since the install I have a clunk from the right front suspension. It happens when I hit a small or large bump. If I hit a dip, no noise. I have changed the damping from soft to hard and it does not help. It sounds like a loose part. We have been over the suspension several times checking all bolts and re-torquing. We could not find anything rubbing. Any ideas? My only thought is maybe a bad strut. Thanks
how much did you lower your car? i have the kw v2 and it was dumped pretty low and it was making some noise as well. i just raised the car today and took it for a spin. went over speed bumps and high driveways didnt hear any noise. you might want to try that to see if it helps.
I had a 1500 mile trip over the last 4 days and the noise stopped around 800 miles into the trip. I am going to check this week to make sure all is still tight and connected. The plastic fender lip is about an inch from the tire. I am also going to raise it a little, on some bumps the tire scrapes the plastic.
Don't those have camber plates? I have been told those can make sounds. No personal experience here though...
squawSkiBum
Oct 2, 2015 09:21 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
