Suspension New GTSPEC R56 front strut brace install pics
Old Sep 29, 2009 | 03:19 PM
  #51
slinger688's Avatar
slinger688
Originally Posted by ron-s mini
The end plates are 3/16" steel, not real heavy like M7 or Craven.
The cross bar is aluminum and looks different because I inverted the bar on my install (I do not like advertising on my car).
The whole assembly is very light (under 6 lbs).
Thanks for the info.
You did a great job in the engine bay.
Old Oct 5, 2009 | 10:38 PM
  #52
eR1c's Avatar
eR1c
Just saw this, I like it because it looks like the only one that will fit w/ aftermarket CAI's ..here's my question,
I have the DDM street intake (w/o the ram intake scoop and top housing). ...will this rub on the DDM street intake (as it does w/ the DDM ram intake)??
Old Oct 6, 2009 | 07:33 PM
  #53
Jupiter Clam II's Avatar
Jupiter Clam II
I have the Ram intake and it doesn't rub on mine at all.
Old Oct 6, 2009 | 10:22 PM
  #54
eR1c's Avatar
eR1c
Thanks,
I just have the street intake ..so I should be good. I like the price. is it pretty easy to install? -just unbolt the 3 nuts/bolts from each side, slide the bar and end plates on and re-bolt. Nothing other to adjust? -correct??
Old Oct 7, 2009 | 08:16 AM
  #55
ron-s mini's Avatar
ron-s mini
Originally Posted by eR1c
Thanks,
Correct - just torque as per manual (25 ft lbs I think).
Old Oct 7, 2009 | 04:40 PM
  #56
eR1c's Avatar
eR1c
have you noticed an improvement w/ this mod? ...sorry to ask so many questions ..I am on the fence as to whether I want to install a set of water and boost guages, BOV, or this strut? ..3 choices! -trying to determine which is the best mod (for my next mod).
opinions welcome!
Old May 8, 2010 | 10:35 PM
  #57
StillwaterMINI's Avatar
StillwaterMINI
www.gtspec.com
Old Sep 4, 2012 | 09:27 PM
  #58
Nitro9's Avatar
Nitro9
I purchased the GT Spec Front Strut Brace not too long ago. I had the Racing Dynamics unit, but when I put in the K&N Typhoon, the two wouldn't work together. Upon putting in the GT Spec, I had issues with the K&N inlet pipe rubbing with the strut brace. I have been running the bar with hot water heater insulation duct taped on the bar until I found this post. I turned the bar over in the mounts and it gave me the clearance so there is no metal to metal contact anymore.
Old Sep 13, 2012 | 05:39 AM
  #59
user 837978240's Avatar
user 837978240
I've ordered the GT Spec FSB as well. I have a DOC CAI. Will post if everything clears well.
Old Oct 29, 2013 | 12:47 PM
  #60
MiniVelvet's Avatar
MiniVelvet
Will it fit a 2011 Base? I think it will be hard to unload the item if it doesn't fit. :D
Old Dec 16, 2013 | 08:03 PM
  #61
MiniVelvet's Avatar
MiniVelvet
There is about 2 mm of clearance . The bar is definitely not touching the box, even when I wiggle it hard. I wrapped the bar with some silicone self-fusing tape just as a precaution.
Attached Thumbnails New GTSPEC R56 front strut brace install pics-wp_002019.jpg   New GTSPEC R56 front strut brace install pics-wp_002018.jpg   New GTSPEC R56 front strut brace install pics-wp_002021.jpg
Old Dec 16, 2013 | 08:30 PM
  #62
papatom360's Avatar
papatom360
Looks good! Do you have a picture from the front?
Old Dec 16, 2013 | 11:34 PM
  #63
MiniVelvet's Avatar
MiniVelvet
Like this?
Attached Thumbnails New GTSPEC R56 front strut brace install pics-img_20131216_110717.jpg
Old Dec 16, 2013 | 11:43 PM
  #64
MiniVelvet's Avatar
MiniVelvet
Front.
Attached Thumbnails New GTSPEC R56 front strut brace install pics-img_20131216_113851.jpg
Old Dec 17, 2013 | 02:40 AM
  #65
Agbullet25's Avatar
Agbullet25
Does anyone know if this brace will clear the JCW Stage 1 airbox?
Old Dec 17, 2013 | 06:50 AM
  #66
MiniVelvet's Avatar
MiniVelvet
Compare your air box with this:
Attached Thumbnails New GTSPEC R56 front strut brace install pics-forumrunner_20131217_064947.jpg
Old Jan 5, 2014 | 04:10 PM
  #67
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the GT brace will clear the Stage 1 JCW airbox
Old Feb 24, 2014 | 06:49 PM
  #68
cambo's Avatar
cambo
Fits with a typhoon; I didn't have any rubbing anywhere. Easiest install yet. Way- thanks, as always, for the ridiculously fast shipping.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Dec 23, 2015 10:36 AM
squawSkiBum
Oct 2, 2015 09:21 AM
