Suspension New GTSPEC R56 front strut brace install pics
has anybody put on the gtspec under strut brace and if they have how is it . the price is right for a easy mod. and i could buy the upper and lower at the same time for the price of just one of the others. i think i read on here that it helps on rough road surfaces. which i drive on alot. if anybody has one on please tell us your thoughts. hopefully its on a r56s.
oh call me what you will...i understand camber but have no desire to adjust it. if i put this brace on what happens? does it just hold whatever it is now...a "factory set up"
am i dumb wanting it "stock" (you won't offend me :-) )
lastly. FYI> i contacted k&n about their typhoon as that's my planned cai and they said this is the only strut brace that will fit with their box.
my car is the car in the photos... it's a GREAT piece... i used to have the M7 front bar but it rubbed various pieces of my car way to much so i ended up sellin that... this bar has now been on my car for quite some time and i have absolutely no problems at all with it! it's a great piece! looks great too!
Hi dunphylj,
I, too, have this strut bar along with the DDM ram air but with the DDM street intake.
I have issues with the strut bar rubbing on the ram air unit and have glued rubber pieces to the bar to keep it from rubbing/rattling on the ram air.
Does yours rub or rattle?
Just received my GTPSEC front strut bar got it mounted and it does rub on the DDMWorks hood scoop and the metal section going from the stock intake tube to the elbow. The rubbing is small but it will leave marks on the bar and scoop.
That looks really nice. I am going to get this one and the underbody brace together. When I did that to my old car man it mad a huge difference. I also plan on getting a rear bar too. Thanx for the link to that company.
Ron-S Mini,
What are the GT Spec strut bar ends that bolt on to the towers made of? Aluminium? or Steel? Is the bar heavy?
Also your bar itself looks quite different from the one in the first post. It looks flat versus oval? Does that make a difference?
Hi dunphylj,
Looks like Ron may have flipped the bar... Cuz the top is ovalish and the bottom flat... Not to mention the GTSPEC badge isn't on it so the flipped bar is my guess
You may be right. I guess they work either way.
The cross bar is aluminum and looks different because I inverted the bar on my install (I do not like advertising on my car).
The whole assembly is very light (under 6 lbs).
