Suspension Rear sway bar end link with 22mm bar on MCS 2004?
Old Apr 24, 2008 | 07:10 PM
tropicatango's Avatar
tropicatango
i just want to know if the stock end link on a mini cooper s 2004 with sport
package are good enough to work with a 22mm ajustable sway bar like mini
madness or alta or its a must to instal those sway bar with stronger end link
like the alta one
Old Apr 24, 2008 | 07:59 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Have you seen the OEM end link? You could run the stock ones, but sooner or later they will fail under the demand of the 22mm bar.
Old Apr 24, 2008 | 08:05 PM
weezer2282's Avatar
weezer2282
My stock endlinks bent after a while with a Hsport Comp bar(22mm effective). Swapped them out for the Alta's when they were on sale.
Old Apr 24, 2008 | 08:12 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The stock endlinks are just barely strong enough to handle the stock bar. The previous statement has no backing in science, but based on how cars are made, it makes sence.
Old Apr 24, 2008 | 10:22 PM
CooperSS's Avatar
CooperSS
40,000 miles, 22mm Alta bar, stock end links, canyons and track days, no problems.
Bill
Old Apr 25, 2008 | 07:26 AM
ScottinBend's Avatar
ScottinBend
Check out the TSW endlinks. best on the market and very well priced.
Old Apr 25, 2008 | 05:05 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Bill
But which hole setting?
Old Apr 25, 2008 | 06:39 PM
AutoXCooper.com
yep got those too, http://www.autoxcooper.com/tsw_suspension.html
Old Apr 25, 2008 | 06:45 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I ran a 22mm madness bar on the middle setting for close to 50,000 miles with the stock end links. The only reason they got replaced was because I added a set of Cross coilovers and also got the Powergrid end links with them.
When the stock ones got taken off they didn't show any signs of fatigue or have any signs that they were going to fail.
Old Nov 16, 2008 | 08:48 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Stock endlinks are OK for street driving and with any upgraded front or rear swaybars.
But you can bend or break them if you exert enough force during track days, high perf driving school or anything else when you are doing hard cornering.
We have lots of autocross and track days (in the past) in my area and I have never seen any problem with any MINI and a stock endlink.
If you think you need more strength then you can get aftermarket endlinks.
If you are doing corner balancing after installing coilovers then you'd need adjustable endlinks.
Old Nov 16, 2008 | 09:03 PM
justintime's Avatar
justintime
I have only bent one stock endlink, I have broken two alta endlinks. However its still uncertain to me if it was my error (I think they had binded, as in the balljointish thing was in a locked state. it happens a lot, and I can tell cause they start making more noise than normal. all I do is go adjust them back to a neutral position and I havn't had any more problems). either way I need them with my ride height
Old Nov 18, 2008 | 10:54 AM
meb's Avatar
meb
...a word of caution with respect to front rod end type endlinks...most do not have the articulation required to work with the mini's suspension and often fail as justintime experienced. Although the stock endlinks are not in theory as strong as some of the aftermarket links, their ball joint design allow the stock endlinks to work very well.
The only after market endlink that should be used on the front is a ball joint type endlink and Powergrid is the only company I know manufacturing these...sold thru TSW at this point.
If you are on a track and an endlink binds - runs out of articulation - the car will more or less skip thru the turn.
Old Nov 18, 2008 | 11:16 AM
quikmni's Avatar
quikmni
I had stock end links with a Hotchkis 25.4mm hollow (about the same as 23mm solid) with no problems for 45,000 hard miles and 3 track days.
I did have a severe overstreer incident that might be attributable to homemade adjustable end links that I thought had enough articulation but might have bound up. I would stick with stock or get Powergrid.
Old Dec 8, 2008 | 03:32 PM
jlloyd's Avatar
jlloyd
I've got the Madness 22mm with stock end links or, rather, I HAD the stock links. Recently (today) I notices a really loud knock every time I hit a bump (no matter how small). The verdict; a snapped end link. So...TSW? Ireland? I need some input as I haven't orderes the new ones yet and my appt at the shop is this Friday.
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
