Suspension HSport Springs - 1 week later
Old Jul 23, 2003 | 12:41 PM
Mjolnir's Avatar
Mjolnir
First: I have the best Wife in the world for buying me these. "Spaceeba maya Golyubka!"
Ok, they've been on the car a week and I absolutely love them. They're softer over the little bumps but appear firmer over the big ones. Probably because they're an inch shorter. It doesn't feel as though you're going to get the fillings shaken out of your teeth though.
I have them in conjunction with the Kosei K-1's and 215 45 17" Yoko AVS ES100's and the Rossier Dyno Research (RDR) adjustable control arms.
I took it to one of the better alignment shops here in Madtown (used them for years and I know and trust them) to have to have it checked. I was also interested in getting it set for a "street" and "track" setup. To keep this short and sweet I run the front as they are and -1.25 camber and 1/32" toe out on the rear. For the track I'll go to a -2.0 with a 1/16" toe out.
This is an easy setup because it is exactly one turn of the adjuster on the control arm.
-Jim
Old Jul 23, 2003 | 12:44 PM
nfo's Avatar
nfo
Mjolnir.
did you install the springs yourself?
i really want a set of these, but my wife isn't quite as supportive of my quest!
you gotta post some pics for us!
Old Jul 23, 2003 | 04:03 PM
Mjolnir's Avatar
Mjolnir
>>Mjolnir.
>>i really want a set of these, but my wife isn't quite as supportive of my quest! :evil: Especially the front-left.
This is a garage dooable project but make sure you can compress the spring WHILE IT IS STILL IN THE CAR. I didn't catch that part and it's not in the dee-rections.
The rear is a snap. 3 bolts off, carefully and attentively take off the top of the shock, swap the spring, put the cap back on, line it up, 3 bolts in, we'll see you at the bar.
I'll get some pics soon but my digital camera is still in Fubaria.
-Jim
Old Jul 23, 2003 | 04:33 PM
nfo's Avatar
nfo
Jim...
thanks for the compliments!
i hate to ask this, but..... how much did you pay to have them installed?
i want to have a ballpark price to check with some shops here in chicago.
i'm ready to get some springs even if my wife isn't!
thanks!
Old Jul 23, 2003 | 04:42 PM
Mjolnir's Avatar
Mjolnir
If you can find someone willing to give you a ride you'll buy them. (Thanks again Ryephile!) I'm not kidding when I say that it's actually a bit softer than factory. Now downtown Chicago is probably another matter.
Rossier charges $50 per hour. He's just south of Stevens Point, WI.
You would have to call him to find out what he would bill (in hours) for this job.
ROSSIER DYNO RESEARCH
1340 Okray Avenue
Plover, WI 54467
Phone: 715-341-2033
Fax: 715-344-9875
Email: info@mini-works.com
http://www.mini-works.com
He's a good friend of mine. Tell him Jim sent you!
-Jim
Old Jul 23, 2003 | 05:00 PM
nfo's Avatar
nfo
thanks Jim,
i don't think i'm ready to drive so far to have them installed....
i'd prefer to do this local if at all possible...
thanks anyway!
Old Jul 23, 2003 | 06:10 PM
SMKKVK's Avatar
SMKKVK
NFO
Give Sol at call at Perfect Power in Libertyville. Believe he's $100/hr.
SMKKVK
>>>>>>>>>>>>&g t;>>>>
Perfect Power Inc.
844 Liberty Drive
Libertyville, IL 60048
Telephone: (847) 367-8837
Fax: (847) 816-6876
E-mail: perpow1@attglobal.net
E-mail: perpow@aol.com
Sol Snyderman, Owner
Sol started Perfect Power, Inc. in 1981. He is an FAA powerplant rated mechanic and has been working on Porsche 911’s for 28 years. Sol’s experience building aircraft engines and racing engines is put to good use on street and race 911’s. Although Perfect Power originally focused on engine development and building, it didn’t take long to realize that to win races would require the same type of effort on the chassis of the car and the coaching of the driver. Now, Perfect Power is as well known for building race cars, setting up chassis and working with drivers as for building engines.
Perfect Power’s clean and beautiful 5,000 square foot facility is located in Libertyville, Illinois. It includes the latest Hunter alignment equipment, corner weighing scales, engine dynamometer and equipment necessary to service all of Porsche’s classic and current cars.
Beth Snyderman, Office Manager
>>>>>>>>>>>>&g t;>
Old Jul 23, 2003 | 06:28 PM
nfo's Avatar
nfo
SMKKVK....
thanks, i know all about sol and would love to use his services....but...
$250 for springs + a few hours labor @ $100 an hour....woah.
still looking for a good hookup that i can buy some beer for!
Old Jul 23, 2003 | 06:36 PM
Brother's Avatar
Brother
Just to confirm what already has been said...I also had the HSport springs installed a week ago. I also Love them. While the differance is not as great as when I got rid of the runflats...there is a differance. The car is truly more of a pleasure to drive and it seems to take the corners even better. Definitely the smaller bumps are handled much nicer, while I think the larger bumps are a little harder. Definitely worth it. I had mine installed at Helix in Philadelphia. Great shop, great guy (Eric) and one hour charge for Labor! :smile:
Old Jul 23, 2003 | 07:03 PM
Sleepless's Avatar
Sleepless
I'm suprised that you are going with toe-out instead of toe-in on the rear. Could you please elaborate on this choice? I was under the impression that toe-in for the rear is better due to added stability.
Old Jul 23, 2003 | 07:40 PM
itsthesize's Avatar
itsthesize
nfo, I did all of my mods to date which is mostly suspension related. I can say that it is actually quite simple. After doing it on my car I can probably say that if I had to do it again it would be approx. 3 hrs max to do all four. I you have any questions let me know. If you want to call me PM me for number, I'm also in the Chgo area.
Peter
Old Jul 23, 2003 | 07:41 PM
Mjolnir's Avatar
Mjolnir
>>Thanks
Hi Sleepless,
Yep, where I went to school that is what I heard too. I'm merely following in someone else's tire marks.
However, the extensive testing at Grassroots Motorsports supports the 1/16" toe out with -1.0 to -1.5 camber setting. You can read about their test car here:
http://www.grassrootsmotorsports.com/minicoopers.html
The Rossier document says it too:
http://www.mini-works.com/rdr_rear_t...stallation.pdf
-Jim
Old Jul 23, 2003 | 07:48 PM
nfo's Avatar
nfo
Peter .......
we'll have to talk very soon!
i have to check out your car, it looks hot.
if my job interview today went as well as i think it did,
i may be able to order a bunch of stuff in the next few weeks!
Old Jul 23, 2003 | 07:55 PM
itsthesize's Avatar
itsthesize
nfo, anytime. Just PM me for number. Basically I bought the MINI for mods, therefore I don't mind sharing anything I have learned. I have ways to go with other stuff tho.
Good nite all
Peter
Ryephile's Avatar
Ryephile
Congrats on your H-Sport's Jim, I knew you'd love 'em!
Enjoy them carefully
Cheers,
Ryan
Old Jul 23, 2003 | 08:51 PM
Chitown_COOP's Avatar
Chitown_COOP
Coordinator :: Chicago MINI Motoring Club
NFO & Peter:
If you guys are doing a spring and arm clinic at some point, I want IN--but just to watch for now! And no, it's not the wife; it's my wallet!
Old Jul 24, 2003 | 11:07 AM
Mjolnir's Avatar
Mjolnir
>>NFO & Peter:
Guys, if you do throw together a clinic I'm only about 2 hours away up in Madison. I'd be happy to lend a hand, opinion or wrench.
Control arms aren't too bad.
-Jim
Old Jul 24, 2003 | 11:08 AM
Mjolnir's Avatar
Mjolnir
>>Cheers,
>>Ryan
Yah. Thanks again.
I think of you whenever I see a sign near a median.
-Jim
Old Jul 24, 2003 | 12:09 PM
MiniRyno's Avatar
MiniRyno
I also have H-sport springs and love them!
It was not a drastic change but they've made a definite difference in the corners.
The big bumps are harsh though!
I live in L.A. and there are quite a few pot holes
and crummy roads to steer clear of.
All in all I love the springs and they're well worth the price...
cheers, ryan
Old Jul 24, 2003 | 01:21 PM
nynone4's Avatar
nynone4
I have the H&R's on my car, and installed them myself. Install is the same as the H-Sports. I'm about 2.5 hours south of Chicago in the Peoria area if you guys need yet another pair of hands or moral support at that spring install party.
Mjilnor - what color are your Kosei wheels? I've had mine painted since came up to pick up that exhaust from you in Rockford. Pics Here
Old Jul 24, 2003 | 05:40 PM
Mjolnir's Avatar
Mjolnir
Hey there!
They're the silver ones. I have a Dark Silver - Black.
How's that Magnaflow? :smile:
-Jim
psmith27616
Suspension
11
Oct 26, 2016 04:57 AM
Manny_cooper
Nov 4, 2015 09:42 AM
PEterChoqu
Aug 26, 2015 08:33 AM
Bennyboy
Aug 18, 2015 07:28 AM
OZMDD
Aug 17, 2015 02:53 PM
