Suspension rear suspention rattle?
Old Jan 24, 2008 | 11:15 AM
tools's Avatar
tools
The rattle happens almost constantly, even on the smallest of bumps. I have checked sway bar links, sway bar, lower control arms, etc. I have a felling it might be the strut bushings. Most of the noise comes from the drivers side but some from both. Is there a way to check bushings without taking the struts out?
Old Jan 24, 2008 | 11:16 AM
tools's Avatar
tools
My Mini has 98,000 miles on it by the way.
Old Jan 24, 2008 | 12:01 PM
glnr13's Avatar
glnr13
i think it's the alta end links... the heim joints are rattling
Old Jan 24, 2008 | 12:23 PM
tools's Avatar
tools
Thanks I will replace them with stock ones and see if it stops the rattle.
Old Jan 24, 2008 | 01:18 PM
tools's Avatar
tools
Yes , that was the problem thank you very much. Alta end links are gone.
Old Jan 24, 2008 | 01:19 PM
glnr13's Avatar
glnr13
Old Jan 28, 2008 | 12:47 PM
ALTA_JOHNL's Avatar
ALTA_JOHNL
Hey, give me a PM or call our head tech Jeff at 503-693-1702. We don't want the ALTA end links just sitting in your garage. If they are truly rattling there is a possibility that the rod ends can be covered under warranty.
Old Jan 28, 2008 | 03:59 PM
tools's Avatar
tools
i HAVE HAD THE END LINKS FOR ABOUT 2 YEARS. hAD 2 OF THE HYMJOINTS REPLACED 2 MONTHS AFTER I BOUGHT THEM. I DON'T THINK I WILL HAVE THEM REPLACED AGAIN. THEY SHOULD LAST LONGER THAN THAT. I WILL BE LOOKING FOR REPLACEMENTS ELSE WHERE. THANKS ANYWAY
Old Jan 28, 2008 | 04:31 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Hi Tools: My personal apologies that you had any issue at all with the setup on the car. We would agree that in MOST situations those should last far longer than that. The salty roads in your area, due tend to wear them faster and as such later versions were updated with a slightly different rod end to help relieve that problem.
To back up what John said above, if you want I would gladly replace the rod ends for you no charge. I simply need the parts back. If you are willing to send them, they would be sent back free and updated. You have to admit that is a better deal than buying something elsewhere? At least you would get some additional use out of your investment!
I understand your frustration, but no reason to spend more money than you have to. (Plus then you don't have to update your signature!-)
Chat soon!
Old Jan 28, 2008 | 05:12 PM
ScottinBend's Avatar
ScottinBend
Boy he didn't waste any time did he..........to bad he didn't take you up on your very generous offer.
My endlinks rattle all the time, but I expected that when I bought them.
Old Jan 28, 2008 | 07:43 PM
EDM's Avatar
EDM
ill pay for you to send me the end links, ill send em to alta
Old Jan 30, 2008 | 12:21 PM
tools's Avatar
tools
It's not that I don't appreciate the offer, but when you've had some of the parts replaced once already, and they didn't hold up than why waste your time and do it again.
Old Jan 30, 2008 | 05:48 PM
ScottinBend
Because the vendor is trying to make it right........sounds like a very decent offer.
Old Jan 31, 2008 | 08:19 AM
tools's Avatar
tools
I agree that it is a good offer, but I have decided to try a different brand and hope for longevity. Being in the tool business as you might figure out, and a bought a tool and it failed the first time, Ok I take it back for repair or exchange then it fails again in the same area then should I continue buying the tool?
Old Jan 31, 2008 | 08:21 AM
tools's Avatar
tools
I am not here to knock Alta's product. I am hear to solve a problem. The end links didn't work for me that doesn't mean they won't work for everyone else.
Old Jan 31, 2008 | 10:45 AM
ScottinBend
But you haven't given them a chance to replace them with the newer/better one.
Hope the new ones work out !
woodstudio
Mar 15, 2020 08:28 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
Sailorlite
Sep 21, 2015 12:00 PM
iclancy82
Aug 11, 2015 09:35 AM
