Suspension Gallery! Show me your lowered MINI!
Old Jan 4, 2010 | 03:40 AM
  #701
jimmyd1's Avatar
jimmyd1
Originally Posted by Gilboyto
A lot of places do still. Its just the 512's that is only available thru discount tires.
thanks i will check them out
Old Jan 4, 2010 | 07:28 AM
  #702
J_'09s's Avatar
J_'09s
I got my vmaxx coilovers today. I'll be installing tomorrow. Pics coming soon!!
Old Jan 4, 2010 | 09:28 AM
  #703
jimmyd1's Avatar
jimmyd1
Originally Posted by BlckJCWGhst
Lol Its Cool I Was Just Trying To Show Off But Yeah That Was A Hell Of A Night, Anyways Back To Pix Of Greatness
Question When I put lowering springs on my mini do I need to replace my rear links? The reason I ask you in because you have them on your list of mods.
Old Jan 4, 2010 | 09:47 AM
  #704
countryboyshane's Avatar
countryboyshane
Cool! I got mine too after the holiday sale but have to wait to install them till spring because of crappy Michigan winters.
What tire size will you be using?
Old Jan 4, 2010 | 11:46 AM
  #705
J_'09s's Avatar
J_'09s
I'm running stock wheels and tires until i get my car out of Spain. The roads are just too narrow and parallel parking is a daily occurrence. Plus things are expensive out here, and finding a good mechanic would be a headache. So stock until this summer when i take my car back to Bama.
Old Jan 4, 2010 | 03:55 PM
  #706
countryboyshane
OK so are you using 205/45/R17 tires? I just wanna know so when we see the pics all of us have a clue.
Old Jan 4, 2010 | 04:28 PM
  #707
BlckJCWGhst's Avatar
BlckJCWGhst
No my friend... The springs are a mod that work great on it's own it doesn't NEED anything to help it with what it's trying to acomplish. On the other hand if you really want to improve the handling some more, get the H&R 22 mil swaybar from Alta ( hit up Chris he'll hook you up ) With that though I do strongly suggest you get the endlinks because you will see how flimsy the stock ones are. The endlinks help the swaybar do it's job which is keeping your *** end in check. Just make make if you do get it start out at the softest setting so you get used to it ( swaybar )
Old Jan 4, 2010 | 05:06 PM
  #708
countryboyshane
Watch out for Alta' endlinks YIKES! Go for TSW or Way Motor Works ones instead !
Old Jan 4, 2010 | 06:02 PM
  #709
LiLReD1's Avatar
LiLReD1
My end links from Alta are just fine. I may go more radical with my rear camber someday, hence why I got them.
Old Jan 4, 2010 | 06:05 PM
  #710
BlckJCWGhst
Yeah Alta's Are Just Fine, Im Telling You I Have So Many Parts From Them And Not A Single Flaw. I Don't Understand How People Have Problems With Them
Old Jan 4, 2010 | 06:08 PM
  #711
glnr13's Avatar
glnr13
end links have less to do with rear camber than they do with rear sway bar load. you'll need adjustable rear trailing arms AKA rear control arms to make bigger camber adjustments than the stock that only gives about .5°
Old Jan 4, 2010 | 06:22 PM
  #712
LiLReD1's Avatar
LiLReD1
Well there's a thing we have in the upper 49 called snow, and when it does that, they put this stuff in the back of trucks called salt, and they sling and throw it eeeeevvverrryyyyywhere. lol Just joshin' ya bro.
But I have seen some pics of some pretty messed up heim joints from doing this because they're pretty open to the weather. I've also heard ALTA has fixed this issue... not sure how or what the difference is. I know people from my mini truckin days who swear up and down against heim joints. I personally like them. And if they go bad, I'll just get some new ones. Not to hard.
My fault, I meant control arms, got my terms mixed up. (my sig says it) My rear is at .75* and front is I think .25*. I do a lot of highway driving, so any more is kind of pointless for me.
Old Jan 4, 2010 | 06:29 PM
  #713
jimmyd1's Avatar
jimmyd1
Ok Cool , I ordered the springs,sway bar, strut tower bar(front) and front tower reinforcement plates, Anything that I should know before cracking into this project?
Old Jan 4, 2010 | 08:21 PM
  #714
J_'09s's Avatar
J_'09s
Ok cool. Yes, i'm running the crown spokes so its 205/45/17 on the dunlop runflats. I dont think im going to go too aggressive because this place has the widest speed bumps I've ever seen. Its up 6 inches then 8 to 10 feet, then back down 6 inches. Its crazy and they are everywhere!! We'll see though.
I'm probably going to rotate the wheels while im at it. Hopefully they dont need balancing. Anyone know of the correct way to rotate? Is it right front to right rear for example??
Old Jan 4, 2010 | 08:52 PM
  #715
BlckJCWGhst
Well For Starters Here Is A List Of Some Tools You Will Need:
Spring Compressors ( x2 For The Springs Of Course )
Basic 3/8 And 1/2 Drive Sets ( To Remove The Struts, Sway Bar And To Drop The Rear Sub Frame )
Either A Special Strut Socket Or A Spark Plug Socket ( To Remove The Nut On The Strut Bolt )
Allen Wrenchs ( To Hold The Strut Bolt While You Remove The Nut, As Well As On The Endlinks )
Adjustable Wrench ( Hold The Spark Plug Socket While You Use The Allen Wrench To Keep The Strut Bolt From Spinning With The Nut )
Jack And Stands
Honestly The Best Advice I Can Give You Is BE PATIENT Don't Rush Anything. If You Run Into Trouble Just Text Me I Can Give You A Walk Through As I Did Everything Myself. Then Again Those Instructions From Alta Are Pretty T*ts . Whats You Name BTW?
Old Jan 5, 2010 | 03:40 AM
  #716
jimmyd1's Avatar
jimmyd1
Jack And Stands
Awesome thanks for the heads up
Old Jan 5, 2010 | 04:39 AM
  #717
countryboyshane
The stock run-flats are non-directional so you can get away with the old method of taking the left front tire to the rear right, and the right front to the rear left.
When you get tires with a clearly noted direction of rotation you're not supposeld to do it that way.
Old Jan 5, 2010 | 07:50 AM
  #718
J_'09s's Avatar
J_'09s
GGRRRRR i wasnt able to get the coilovers put on today. Work intervened so i am going to try and do it at some point this week. I'll post pics whenever i get it done. So now i have a full turbo back exhaust and coilovers sitting in my living room. I guess thats not a bad problem to have Thanks Shane for the input!!
Old Jan 5, 2010 | 09:41 AM
  #719
countryboyshane
Ha, I wouldn't complain that much man, I'll be having my coilovers sit in my closet for THREE MONTHS!
Looking forward to pics of the new stance!
Old Jan 5, 2010 | 11:08 AM
  #720
VicSkimmr's Avatar
VicSkimmr
Less talk, more pictures please
Old Jan 5, 2010 | 11:14 AM
  #721
SebM's Avatar
SebM
Oh yes !!! Amazing !! More pictures please !!!
Old Jan 5, 2010 | 11:16 AM
  #722
VicSkimmr's Avatar
VicSkimmr
http://www.flickr.com/photos/jasonwi...7618320603651/
Old Jan 5, 2010 | 07:48 PM
  #723
jimmyd1's Avatar
jimmyd1
that is one hot S .....White Hot! psssssssssssssssssssssk ouch!
Old Jan 5, 2010 | 10:49 PM
  #724
SebM's Avatar
SebM
Thanks !!! Very nice pictures also !!
Old Jan 6, 2010 | 06:52 AM
  #725
empire0007's Avatar
empire0007
I loke those rims. Do you have a side picture of your car
