Suspension Gallery! Show me your lowered MINI!
Old Jan 6, 2009 | 08:08 AM
  #251
Red Bull's Avatar
Red Bull
Originally Posted by Mach V Dan
Trust me, 99% of people with coilovers NEVER adjust their ride height once they're installed. Why? It's a huge chore. As mentioned, the threaded bodies get grit and corrosion on them, which makes moving the perches difficult, if not impossible. Even if they were pristine, it's quite time consuming. Jack up car, remove wheel, adjust coilover, repeat x 4, replace wheels, put car back on ground, evaluate height, repeat until done.
I'm not saying coilovers aren't worth it. I'm just saying, don't think you're going to adjust the ride height all the time. Nobody I know does that.
--Dan
Mach V
FastMINI.net
I guess I am in the 1%...I have changes my ride height several times and I do not find it difficult as you say....It is not a huge chore.....It takes me about an hour to make the adjustments...not hard work and I get to clean everything up while I do it.
Old Jan 6, 2009 | 10:34 AM
  #252
cooldaddy's Avatar
cooldaddy
amen, it really is not that difficult.
if you're picky about the cars 'stance' coil-overs are the only way to go... especially if you change wheels & tires sizes over time, real easy to get the stance right again...
Old Jan 6, 2009 | 04:08 PM
  #253
scho06's Avatar
scho06
Before after photo
Just came across a pic of the before/after my Bavauto spring install.........
Old Jan 6, 2009 | 04:45 PM
  #254
iwashmycar's Avatar
iwashmycar
QUICK QUESTION for you guys...
If i pick up some H&R springs... will I need anything else??.. can it be properly aligned still?
Last car I lowered was my 90 Mustang and it got all out of whack and needed Caster/Camber plates to get back to spec
You guys will know best! These pics are incredible..huge difference. Hope to have mine up here soon!
Old Jan 7, 2009 | 04:11 PM
  #255
oldcracker's Avatar
oldcracker
Old Jan 7, 2009 | 05:09 PM
  #256
Oxybluecoop's Avatar
Oxybluecoop
You won't need anything else and yes it can still be aligned.
Old Jan 8, 2009 | 04:53 AM
  #257
iwashmycar's Avatar
iwashmycar
saweeeet thanks
Old Jan 9, 2009 | 04:44 AM
  #258
Coen_de_K's Avatar
Coen_de_K
same here... and the rear and you can adjust with the wheels on :D just jack the car up!! :D
Me like adjusting toooooo :D
cheers
Coen
Old Jan 9, 2009 | 06:43 AM
  #259
Red Bull's Avatar
Red Bull
cheers
Coen
You are correct.....just did a little adjustment on the rear last night. I have a lift but dropped the rear another 1/4" under 30 minutes from start to finish and no busted knuckles
Old Jan 9, 2009 | 07:04 AM
  #260
Rally@StanceDesign's Avatar
Rally@StanceDesign
Yup...agree on both accounts. If you're gonna get the stance right, you'll be turning them up and down until it sits perfectly
Old Jan 11, 2009 | 02:07 PM
  #261
roofaS's Avatar
roofaS
But don't you mess up the alignment with each height adjustment?
Old Jan 11, 2009 | 03:27 PM
  #262
investigator's Avatar
investigator
Good question. When I lowered mine with springs only (no coilovers) an alignment was done immediately after. I also wonder if every time someone with coilovers changes the ride height is an alignment necessary.
Old Jan 11, 2009 | 03:56 PM
  #263
Red Bull's Avatar
Red Bull
Not if your only doing adjustments of 1/4 to 1/2"...does not cause a problem at all. Think about when you have a person sitting in the car how that lowers it.
I went for an alignment after a 7/8" drop and it still was in spec. So now when I do small adjustments under 7/8" I dont worry about it and I am not having any issues.
Old Jan 12, 2009 | 02:07 AM
  #264
Ben-Ja-Min's Avatar
Ben-Ja-Min
Red Bull what ride height are you set at now, front and rear?
Old Jan 12, 2009 | 04:36 AM
  #265
BDBMCS's Avatar
BDBMCS
Just wondering.....to you guys with lowering springs, do you notice hitting the bump stops more often or at all? When I lowered my pickup seemed like any speedbump would have the rear banging on the bumpstops. I'd like to lower my Mini, but not at that price.
Old Jan 12, 2009 | 06:27 AM
  #266
IzzyG's Avatar
IzzyG
Peter at M7 tuning mentioned that all you need for realignment are rear camber links. I was planning on installing coilovers that easily adjust for winter(close to stock height) and for summer(almost slammed position).
Old Jan 13, 2009 | 06:59 AM
  #267
Mini Fireman's Avatar
Mini Fireman
Even if you are lowering quite a bit, you do not NEED adjustable camber plates and rear control arms to keep workable alignment specs. That said, it is very helpful to have the extra adjustability to allow you to tune the suspension to reflect what you want it to do.
IMO, if you want to lower your car then go straight to coils. The VMaxx are too inexpensive and quality to waste your time/money on lowering springs that will prematurely wear out your stock struts. Lowering springs and stock struts=the cost of VMaxx essentially.
Old Jan 13, 2009 | 07:01 AM
  #268
Mini Fireman
Depends on the spring you use, but in general, no.
/threadjack
Old Jan 17, 2009 | 10:18 AM
  #269
BlackSapphire's Avatar
BlackSapphire
Originally Posted by snkbte
H & R Springs...non-runflats. Rides better then stock.
I know this is an old post but this is one of my favorite cars on the forum so far. I'm thinking of buying an all PW '09 MCS right now and this makes my decision that much easier. I've got H&R on my 2003 540 M-tech right now and I've been happy with them. Sounds like I might just stick with the same company. Also looking at the Eibach Pro Street Kit (coilovers)... they are on the low end of coilover prices and I don't see much about them on here.
Regardless, well done.....nice and classy.
Old Jan 18, 2009 | 11:47 AM
  #270
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Check out my flickr page for more of this type setup!
CLICK HERE
Old Jan 18, 2009 | 02:32 PM
  #271
Minitauro's Avatar
Minitauro
KW V1's and Alta lower control arms
Old Jan 18, 2009 | 02:39 PM
  #272
MakoBimmer's Avatar
MakoBimmer
Looking good, Minitauro!
Did you really need lower control arms or did you just get them because you thought you might need them? Do tell.
Old Jan 18, 2009 | 03:21 PM
  #273
Minitauro's Avatar
Minitauro
Thanks. I figured I may as well get them for the added adjustability, but I don't think it's necessarily a "must have" unless you are going for some serious drop. I can say they are some very nicely made pieces.
Old Jan 18, 2009 | 06:09 PM
  #274
Oxybluecoop
Mounted new 225/40/18's on the front yesterday.Added a bit more negative camber to prevent too much rubbing against the arches.
Old Jan 18, 2009 | 06:46 PM
  #275
Red Bull's Avatar
Red Bull
Looks great man
