Suspension Shocks for R56
Old Aug 21, 2007 | 10:49 AM
mikeg4572's Avatar
mikeg4572
Shocks for R56
Anyone know of any shocks that are out for our car yet? I have lowered mine with the H&R springs and am looking to replace the shocks. Can I use the Helix R56 Rear Shock Bushings with R53 shocks?
Thanks!
Mike
Old Aug 21, 2007 | 11:52 AM
Turn In Concepts's Avatar
Turn In Concepts
I believe you can or at least should be able to with the helix bushings. The tophats in front are different so you'll need to put your R56 hats on the struts.
Old Sep 23, 2007 | 09:19 PM
mikeg4572's Avatar
mikeg4572
Anything out yet? Still looking for shocks.
Old Oct 8, 2007 | 07:25 PM
mikeg4572's Avatar
mikeg4572
Whats talking so long? Is is complicated or are the after market companies just taking their time?
Old Oct 8, 2007 | 08:01 PM
r56mini's Avatar
r56mini
Why are you trying to replace the shocks? Is the ride bouncy? Any sign of under-dampening?
Old Oct 8, 2007 | 08:08 PM
lhoboy's Avatar
lhoboy
A lower, stiffer spring will require a higher dampening rate from the shock. Otherwise you get a choppier ride.
Old Oct 8, 2007 | 10:31 PM
lttletimmy's Avatar
lttletimmy
it looks like outmotoring has koni yellows on their site, hope that helps.
Old Oct 10, 2007 | 03:15 PM
Turn In Concepts
Dude - just about anything for the R53 should work, but you'll need the helix trailing arm bushings for the rear.
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Suspension Products
Sep 3, 2015 09:41 AM
