battey/jump start HELP!!!!
Old Nov 4, 2006 | 06:31 AM
SpiderX's Avatar
SpiderX
I went out to start the car and the solenoid clicked and then I tried to push it down the hill in 2nd and nothing (engine seemed to turn over) I tried to jump it with cables.... more clicking.... removed the battery and connected strait to the cables with two diferent cars and more clicking... took battery and had it tested ...9.1 volts... battery is now being charged..... I can't figue out why it would not start by pushing or jumping.... any ideas?????? :impatient
Old Nov 4, 2006 | 06:46 AM
Alerious's Avatar
Alerious
I had the exact same issue with my battery. Now I don't know if whether this is accurate or not, but from what the MINI service manager told me after I had my car towed in for the same problem, it has to do with the battery shorting out a component inside preventing it from being jump started. All that is really necessary is to switch to a non-OEM battery and you shouldn't have a problem in the future with jump starting if need be. I apologize for not being able to get into any specifics, but just relaying what I've been told.
GotMINI
Old Nov 4, 2006 | 07:07 AM
cartar452's Avatar
cartar452
maybe thats why they had the battery recalls...i never had a problem but i took mine in and they gave me a new one
Old Nov 4, 2006 | 07:45 AM
kenchan's Avatar
kenchan
i thought the recall was for MC's.... spiderx- you have a MCS, right?
Old Nov 4, 2006 | 08:34 AM
Rawhyde's Avatar
Rawhyde
Even if you push the car off, you must have enough electrical power in the battery to run the fuel pump and the injectors. At 9.1 volts, you are well below what you need, and the alternator doesn't put out quite enough at idle to compensate for such a weak battery.
Rawhyde
Old Nov 4, 2006 | 02:32 PM
SpiderX's Avatar
SpiderX
problem solved.... k-huevo (thanks K) was nice enough to send me to a thread about the problem...... with that insight I bought a new battery and problem solved..... the battery was on its last legs..... read the thread which I am no good at posting but a search will help you
Old Nov 4, 2006 | 03:26 PM
ProfessorDave's Avatar
ProfessorDave
I always wondered if you could push start modern cars with a clutch switch. So this is possible as long as you have enough juice in the battery for the fuel pump?
Old Nov 5, 2006 | 12:10 AM
norm03s's Avatar
norm03s
Your sure you don't know how to copy and paste a thread?
Like this maybe;
https://www.northamericanmotoring.co...ad.php?t=83499
Old Nov 19, 2006 | 12:54 AM
JJ Blue's Avatar
JJ Blue
norm03s posted
Like this maybe;
https://www.northamericanmotoring.com...ad.php?t=83499
That was helpful to the topic.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
Steffen.Johnson
Aug 23, 2015 08:30 PM
