Help diagnosing the noise.
Old Aug 14, 2006 | 09:23 PM
goaljnky's Avatar
goaljnky
Here is the situation. I have a 2005 MCc riding on H-Sport springs with 25 mm sway bar and an M7 USS. All parts were installed by Steve's Auto Clinic. I have a squeaking/groaning noise coming from the rear mostly going over bumps and dips. At first I thought it might be the sway bar, so I had it lubed up through the grease fittings, but the noise is still there. Than I thought it might be the top (since it was replaced by the dealer), but the noise is there whether the top is up, or down.
So my question is this. Could it be the weak OEM MCc shocks making the noise? Or could it be the springs since the shocks are shot and the springs are doing all the work now?
All opinions are welcome as this noise is getting annoying.
Thanks.
Old Aug 14, 2006 | 09:52 PM
SRTech's Avatar
SRTech
Thanks.
I have found it hard to get much grease through those zerk fittings. Try again by taking out the bushings and lubing them up liberally inside and out.
Steve
Old Aug 14, 2006 | 10:14 PM
caminifan's Avatar
caminifan
Steve
And, the jerk fittings do not uniformly flow the grease. I would agree with SRTech to try a direct intervention at manually greasing the bushings.
Old Aug 14, 2006 | 10:23 PM
latte hiatus's Avatar
latte hiatus
Something that's worked for me well in the past is to have someone else drive your MINI. Walk alongside as the driver takes your MCc slowly over some bumps and dips, and try to make any observations about what you see and hear and exactly when the squeaking/groaning occurs (i.e., whether it's occurring as the back is rising or falling). You can also use this method to eliminate some potential causes, such as tire rubbing or spring bottoming out. The process only takes a few minutes, and it could save a lot of trouble down the road.
Best of luck, and keep us posted!
Old Aug 17, 2006 | 10:11 AM
MassMini's Avatar
MassMini
I had a groaning/creaking noise in my '05 MCSc coming from what I thought was the rear window mechanisms. Read a post somewhere stating that it could be the door latches and to try lubing them with white lithium grease spray. It solved my problem.
Old Aug 17, 2006 | 01:46 PM
goaljnky's Avatar
goaljnky
Was that while driving?
Old Aug 27, 2006 | 02:58 PM
goaljnky's Avatar
goaljnky
Just an update. The prize goes to Steve, aka SRTech. I had the bushings removed and re-greased and all is quiet once again.
Old Aug 31, 2006 | 05:02 PM
SRTech's Avatar
SRTech
Glad I could help! I win one once in awhile.
Steve
Doc Pain
Mar 10, 2021 04:50 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Chefben63075
Oct 1, 2015 12:04 PM
Miniwaukee
Sep 29, 2015 09:22 AM
silence2-38554
Sep 28, 2015 12:19 PM
