Ok kids... let's talk about SKIDPLATES!
Old Feb 18, 2006 | 10:52 AM
moreorless's Avatar
moreorless
My May build '02 appears to be a bit over exposed under the engine. You remember the power steering fan without a cover right? Well I installed a fan cover off of an old Sun server muffin fan. But I still have concerns about the exposed under pinnings in the front. We can get some pretty serious snow here on the northshore of the USA (Ohio) and I've already felt the snow ruffle along the underside of the car. Not a pleasant sound. Salt is used prodigiously in this region as well. Does "rustbelt" ring any bells?
So, all you old time owners of the new MINI, what's your thoughts on skidplates? Worth the investment? Who's got what available? Stainless vs powder coated? I'll be fitting a Fumoto without nipple, does that matter? Does that help?
What say you?
...Les
Old Feb 18, 2006 | 12:00 PM
caminifan's Avatar
caminifan
Originally Posted by moreorless
...So, all you old time owners of the new MINI, what's your thoughts on skidplates? Worth the investment? Who's got what available? Stainless vs powder coated? I'll be fitting a Fumoto without nipple, does that matter? Does that help?
A skid plate definitely helps protect the underside of the car. The only skid plate that I am aware of is one that is sold by Mini Mania. See this URL: ( http://new.minimania.com/web/Item/NM.../InvDetail.cfm ). The downside of the Mini Mania plate is that it will corrode based on exposure to your salted roads. The best solution to the corrosion issue would be stainless steel. If someone knows of a stainless steel skid plate, I would love to hear about it. A Fumoto with nipple should be fitted if you are going to also fit a skid plate.
Old Feb 18, 2006 | 12:19 PM
UKSUV's Avatar
UKSUV
I bought my skidplate from MossMini for $40 when it was on sale. Normally $140. It is heavier than crap. I am probably going to drill holes in it to lighten it up. I like it though. Easy to install and remove. Like I said.....just a little heavy. They have the aluminum one @ 9lbs. but it goes for $160
Old Feb 18, 2006 | 01:06 PM
maxmini's Avatar
maxmini
I have the Moss Stainless unit as well. It is on the heavy side , just under 20 lbs but at least the weight is down low. The plate gives excellent protection but there MAY be a undesirable side affect. Twice on a hard canyon run in the middle of summer I over heated the steering system and lost the power steering.Now this is in L.A CA and was on a tight mountain road with lots of elavation changes so it was getting a workout. This may have been a coincidence but it does bare mentioning. There is less fresh air getting to the bottom of the motor but there are also less rocks , bricks etc .
Randy
M7 Tuning
Old Feb 18, 2006 | 01:11 PM
Crashton's Avatar
Crashton
Les, I think a skid plate is a good idea. When I took a look at the bottom of my MINI it just screamed I need a skid plate. Not only is that fan in harms way, but that cast aluminum oil pan is just waiting for a rock or iceberg. Yesterday I ordered one from Moss. They had some that were for early year MINI's at a very reasonable price recently. You may want to check them out.
Edit...Randy did you lose the steering due to the electric motor heating up or was it the fluid that heated & cavitated? One more question...does the plate have to come off at oil change time? Thanks.
Chuck
Old Feb 18, 2006 | 01:29 PM
caminifan's Avatar
caminifan
Originally Posted by Crashton
...One more question...does the plate have to come off at oil change time? Thanks.
That is the reason for getting a Fumoto valve with a nipple - to be able to drain the oil without removing the skid plate.
Old Feb 18, 2006 | 02:16 PM
moreorless's Avatar
moreorless
This is good stuff gang....appreaciate the replies......yes I'll be using a Fumoto but I'm not sold on the nipple requirement yet. I guess that may depend if a skidplate is installed. It seems to me the Fumoto with nipple extends down a bit to far for my comfort without a skidplate to protect it.
Keep talking gang.....Les
Old Feb 18, 2006 | 02:27 PM
XAlfa's Avatar
XAlfa
Randy
M7 Tuning
Not a coincidence. I've read about this happening to others with skid plates.
Old Feb 18, 2006 | 02:28 PM
Crashton's Avatar
Crashton
I won't be putting one of those Fumoto's on my car. They just seem pretty darned fragile to me. If I need to I will take a hole saw & make an access hole where I need to in the skid plate.
Chuck
Old Feb 18, 2006 | 03:01 PM
trackster's Avatar
trackster
A skid plate is great insurance if you plan on tracking your car . We had a local guy go off track, not in a big way but he did not stop to look under his car immediately and drove back to the pits. He did not realize that he had put a hole in his oil pan and completely fried the motor in about 500 yards. By the time those lights go off it is usually too late.With the adrenalin pump of going off road many are just happy to hear the motor still running and the car able to move and continue on.His car was low as most of ours and in the soft infiend even if he had gotten out to look he would not have been able to see an oil sopt. As this guy proved that is not a good idea. Skid plate would have saved his bacon for sure.
John
Old Feb 18, 2006 | 05:51 PM
caminifan's Avatar
caminifan
I was only proposing the Fumoto with nipple IF you got the skid plate. Absent the skid plate, there is really no reason to get the nipple option.
Old Feb 18, 2006 | 07:29 PM
moreorless's Avatar
moreorless
Point taken.
Now what about easy removal of the skidplate? There's been rumors about not bbeing able to remove the skidplate after a period of time. What's the real story on that?
....Les
Old Feb 18, 2006 | 08:13 PM
maxmini's Avatar
maxmini
Point taken.
....Les
I have not seen that to be a problem with the Moss Stainless one that I have. I am in California and we don't get as much corresion etc as other areas so that may be a factor.
Randy
M7 Tuning
Old Feb 19, 2006 | 12:18 AM
cooper99's Avatar
cooper99
Sorry to disagree with the group, but I think a skid plate is functionless for 99% of Mini drivers, unless you want "bling". I bought the Moss Mini aluminum skid plate last spring because I had my car lowered and I have a steep rocky driveway. It had no problems, but I disliked the thought of extra weight and also I read some thread on here where someone was trying to take it off to change their oil but the bolts were rusted on. Also someone said the dealer charged them an hour labor to take it off and put it back on for their scheduled mantainence...
So... I sold it to The MINTOR for a good deal and I hope hes enjoying it now. I think the little power steering fan plate is a much more practical way to go.
Old Feb 19, 2006 | 04:52 AM
Jerseygirl's Avatar
Jerseygirl
I've got the Moss stainless skidplate and it was definitely worth the price and the added weight. Mine has several nice big scratches in it so it has defintely proven it's worth to me. As far as the rusty bolts go, yes, the bolts that came with the skidplate were crap and we had trouble getting them out the first time. My boyfriend then ditched those and went out and bought some new stainless steel bolts and has since had no trouble removing them when he needs to get the skidplate off.
We opted not to get a Fumoto because he actually prefers to remove the skidplate while changing the oil. He says it's a good time to get under the car and do a visual inspection for any leaks or other potential problems that you might not be able to see with the skidplate on.
Old Feb 19, 2006 | 10:23 AM
Crashton's Avatar
Crashton
Robyn, your boyfriend has the right idea. I have an idea for you...For those that only want to use the skidplate on track days you could make & market a skidplate bag. It would compliment your other line of fine bags.
Chuck
Old Feb 19, 2006 | 11:02 AM
moreorless's Avatar
moreorless
That's a good point on visual inspections. I'll probably still do a Fumoto, I'd rather not be unscrewing and screwing into the aluminum pan. Stainless bolts are an excellent suggestion by the way.
I guess I'll do a search on stainless skidplates and see whos got what. Unless someones got an orphaned plate abandoned in their garage.
....Les
Old Feb 19, 2006 | 11:44 AM
maxmini's Avatar
maxmini
Originally Posted by cooper99
Sorry to disagree with the group, but I think a skid plate is functionless for 99% of Mini drivers, unless you want "bling". I bought the Moss Mini aluminum skid plate last spring because I had my car lowered and I have a steep rocky driveway. It had no problems, but I disliked the thought of extra weight and also I read some thread on here where someone was trying to take it off to change their oil but the bolts were rusted on. Also someone said the dealer charged them an hour labor to take it off and put it back on for their scheduled mantainence. AND finally, I talked to Ryan at Detroit Tuned a while back and he said that hes never seen a scratch on any skid plate so that gave me some more reassurance to take it off. Then I sold it to The MINTOR for a good deal and I hope hes enjoying it now. I think the little power steering fan plate is a much more practical way to go.
Well this will be fun. Bling for ants is something I had not thought about. As for never seeing scratches on a skid plate check these out. No I did not photo shop LOL . One scratch in particular brings back the non fond memory of seeing a softball sized rock emerge from between the rear wheels of the M3 in front of me on a canyon road about .5 seconds before it went under my car. I felt the contact and watched the rear view mirror to see a trail of oil but the plate did its job and I wasn't even on a track. That is where the majority of the rest of them came from . Functional yes, bling for ants maybe .
Randy
m7 Tuning
Old Feb 19, 2006 | 12:40 PM
UKSUV's Avatar
UKSUV
My skidplate has protected me several times. It takes 5 minutes to pull off for maintenance. True, the bolts were pretty hard to get out the first time and I had to be careful not to strip them.
Old Feb 19, 2006 | 12:49 PM
caminifan's Avatar
caminifan
I don't know what the roads are like elsewhere, but northern California can probably qualify for certification as the worst collection of road debris and potholes as a result of the recent rains. Take your car out without some form of underbody protection and you are rolling the dice. Oh and by the way, if you hit anything and there is a catastrophic failure (engine gets fried, transmission holed, or...), it is covered by your collision policy (not comprehensive), which usually has a higher deductible and you may be looking at a rate increase if you file a claim (on the theory that you hit the object rather than drove around it). Take note from the scratches on Maxmini's plate....
Old Feb 19, 2006 | 01:09 PM
moreorless's Avatar
moreorless
Thanks for all your input and suggestions. Well now it's not a question of if but a question of which one. Hi ho, Hi ho it's off shopping we go......Les
Old Feb 19, 2006 | 01:33 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
FYI, Moss Mini is currently running a sale on the aluminium skidplate for only $119.95.
It is at the top of my current shopping list. Sale ends 24 Feb 06.
Old Feb 19, 2006 | 01:34 PM
K9MINI's Avatar
K9MINI
Does anyone know what size thread tap I should use to clean up the threads used to secure the skidplate?
Old Feb 19, 2006 | 03:53 PM
Crashton's Avatar
Crashton
Thanks for the pictures Randy. Like they say worth a thousand words. 2 thousand for this post. To me it looks like you can get to the drain plug with the plate on.
Chuck
Old Feb 19, 2006 | 04:35 PM
maxmini's Avatar
maxmini
No Problem . I hate seeing information passed around that may not be accurate. You can get to the drain plug with no issues.
Randy
m7 tuning
