Ok kids... let's talk about SKIDPLATES!
Originally Posted by caminifan
I don't know what the roads are like elsewhere, but northern California can probably qualify for certification as the worst collection of road debris and potholes as a result of the recent rains. Take your car out without some form of underbody protection and you are rolling the dice. Oh and by the way, if you hit anything and there is a catastrophic failure (engine gets fried, transmission holed, or...), it is covered by your collision policy (not comprehensive), which usually has a higher deductible and you may be looking at a rate increase if you file a claim (on the theory that you hit the object rather than drove around it). Take note from the scratches on Maxmini's plate....
Originally Posted by K9MINI
Does anyone know what size thread tap I should use to clean up the threads used to secure the skidplate?
Rob.
Originally Posted by UKSUV
Were you talking to me? I have a skidplate
Originally Posted by Bilbo-Baggins
FYI, Moss Mini is currently running a sale on the aluminium skidplate for only $119.95.
It is at the top of my current shopping list. Sale ends 24 Feb 06.
Neil
05 MCS
96 M3
Just got done doing my first oil change & installing my Moss aluminum skid plate. Pretty easy install & it looks like it'll do a fine job of protecting the underbelly of my MINI.
Don't know if this is the right thread (or OT: Movie Oneliners??) but "ain't never seen a skull come apart like that before) rings true from Platoon or Casulties of War type Vietnam flicks as well as what a Moss steel skidplate will do to a recalcitrant 'possum caught unaware at 3:00 in de a'yem.
If you drive your MINI constantly (and who among us doesn't?) you'll eventually have need for one of these to protect your engine's vulnerable underside. Mine's come in handy on the Interstate where it is oftentimes impossible to change lanes when debris (flotsom and jetsom to the nautical set) magically appears in your path. Get the heavy duty, hard core version and sleep easy.
I wished I read this thread alot sooner. On a pie-tin rally this weekend my chin spoiler topped a baseball-sized rock causing it to 'jump' up and crack my oilpan. Insurance is covering it minus my regular deductible. I was following another car and did not have the time/space to react.
i deffinately want to get a skid plate but i can't figure out if the extra weight of the steel vs the Al one has that much of an extra benifit
anyone happen to know the thickness of either/both of these plates for comparision purposes?
I can't tell you anything about the steel one. I do have the aluminum one & to me it seems darned sturdy. If you are going to run rallies then get the steel one. For normal use the aluminum will be fine.
yeah i dont think i will be doing any rallying with my current ground clearance (one of the reason i want to get said item)
do you remember before you put it on your car wether or not it could support itself or how much it sagged at the opposite end if you held it at just one side? if that makes sense
could be, they are a rival Big Ten school ( i go to U of M Ann Arbor)
it might also be due to the extreme drop off between the road and pull off areas on the dragon
and my appetite for autoX cones
bradstyle
Oct 1, 2015 11:15 AM
