Home made ramps?
Old Sep 21, 2005 | 03:12 PM
blue agave's Avatar
blue agave
Home made ramps?
I want to build a set of drive on ramps so I can service and mod from the bottom up. I was thinking of using Rhino ramps for the incline, but seek advice on how to support the horizontal surfaces. Anybody built a set of these?
Old Sep 21, 2005 | 05:18 PM
2Miniacs's Avatar
2Miniacs
Not mine, but I was going to make a set like this. Has a removable middle section and can be built to many different sizes.
Old Sep 21, 2005 | 05:44 PM
ScottinBend's Avatar
ScottinBend
Hard to beat $20 for a set of ramps.
Good luck.
Old Sep 21, 2005 | 06:24 PM
blue agave's Avatar
blue agave
Cool looking ramps 2Miniac. Looks easy to build. If it can keep a vette from crashing down on you, it will be guaranteed safe for an MC. Looking it over, I am having visions of making a bar that spans either the 2 front or rear jacking pads so the 2 wheels can come off he ramp and jack stands inserted undernearth the chassis. Mmmmm . . . could work
Old Sep 21, 2005 | 06:25 PM
MiniMe05's Avatar
MiniMe05
Two sets of rhino's works well too.
Old Sep 21, 2005 | 07:19 PM
kenchan's Avatar
kenchan
just don't put your car on cinder blocks... ive seen them get crushed under the tire.
Old Sep 22, 2005 | 04:47 AM
daleCarlsbad's Avatar
daleCarlsbad
I made a set many years ago out of twelve inch wide by one inch thick wood. The sketch below is what they looked like. Kind of heavy (a good thing) and plenty sturdy. Considering the cost and time to build these, it would be easier to buy a set of ramps from Pep Boys, although with the home made design, once the car is up there, you could remove the ramp section and free up that area behing the wheel.
Old Sep 22, 2005 | 04:57 AM
OKeefe's Avatar
OKeefe
ramp plans
ramps are a fairly common learner's project for welding 101 classes. there are plans available both on line and probably at your library.
however the cost in materials will exceed the cost of rhino's easily....that assumes you have access to a welder and someone who knows how to do it.
you might see if a local school has a vo-tech welding class. you might swing a deal where you provide the materials and they weld 'em up for you...sometimes they are looking for projects.
With a decent MIG unit and about a hundred feet of 1 inch angle iron ... hmmm
Old Sep 22, 2005 | 07:09 AM
blue agave's Avatar
blue agave
Thanks everyone. The problem with Rhino's is that they hold one end of the car off the ground and leave the other on the floor. The car sits at an incline. I want to get both ends up. What I have in mind looks more like 2miniacs posted pix. I just figured that rather than toss out the Rhino's I own, I could use them for the inclined part of the ramp to drive up onto the horizontal section.
Old Sep 22, 2005 | 08:23 AM
The Short Bus's Avatar
The Short Bus
I need to stop scrolling through the titles so fast... i thought it said "Home Made Rumps"
Old Sep 22, 2005 | 05:53 PM
cantdrv55's Avatar
cantdrv55
Wish I had a grand to spare. This lift is cool.
http://www.kwiklift.com/
Old Sep 22, 2005 | 09:27 PM
kenchan's Avatar
kenchan
when i did my exhaust and shortshifter, i just did the rhino ramps on the
front and used jackstands on the rear. just make sure your car is in gear.
Old Sep 23, 2005 | 05:34 AM
2Miniacs's Avatar
2Miniacs
[QUOTE=cantdrv55]Wish I had a grand to spare. This lift is cool.
http://www.kwiklift.com/[/QUOTE]
If you're going to go with a lift then you're better off with one like in my gallery....... Much more useful.
Old Sep 23, 2005 | 06:17 AM
LeeL's Avatar
LeeL
About how much, if you don't mind?
Old Sep 23, 2005 | 07:46 AM
cantdrv55's Avatar
cantdrv55
Forget the lift. Now I have garage envy!
Old Sep 23, 2005 | 08:22 AM
IanF's Avatar
IanF
The Kwiklift is kinda neat... and I do like the portable aspect of it... but it's a bit expensive when a more useful two-post lift can be had for a few hundred more.
I do like the wood ramps in the Vette picture.
Old Sep 23, 2005 | 08:33 AM
Nuff's Avatar
Nuff
I know someone already mentioned this before, but why not use 2 sets of Rhino's? Put one set under the front and one set under the rear and just drive up. Should raise the front and rear at the same time. I've done this with other cars (but never tried it on my Mini).
Old Sep 23, 2005 | 10:05 AM
blue agave's Avatar
blue agave
Yup. The model for $999 is what I had in mind in terms of function. I think it can be built from 2x lumber for much much less. I like the idea posted earlier in this thread (with pix) of the wood ramp and "lift" with removable center sections so you can get in and out on a creeper.
embiggenedmini
Oct 15, 2015 12:36 PM
Sc00terbum
Sep 11, 2015 07:17 AM
renchjeep
Sep 6, 2015 01:54 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Ryan Caballo
Sep 4, 2015 12:20 PM
