Is your car stalling upon starting?
Old Apr 14, 2006 | 10:37 AM
  #276
mdsbrain's Avatar
mdsbrain
shoeboy that problem I believe was fixed with a software update a log time ago from MINI. If your car hasn't gotten it then it could use it!
There were also mentioning of summer gas causing this problem.
Can anyone else shed light on this problem? Thankfully my car stopped doing this after a few thousand miles.
Old Apr 14, 2006 | 10:48 AM
  #277
shoeboy's Avatar
shoeboy
Thanks, I'll look into that. I bought my car used, so I cannot account for everything that has (or has not) been done. Unfortunately the nearest dealer is 2.5 hours away, so I'll have to wait until my next service to do anything about this.
Old Apr 14, 2006 | 01:38 PM
  #278
Silenpro's Avatar
Silenpro
how do you reset the ecu ????
Old Apr 27, 2006 | 07:00 AM
  #279
moraine's Avatar
moraine
i dont know if this question has been answered and i really dont know much about engines .. im interested in getting a regular '06 mini cooper .. should i expect to have these stalling problems?
Old Apr 30, 2006 | 06:49 AM
  #280
snooter's Avatar
snooter
Mr. MOTD
Originally Posted by MINIotaple
My '06 MCS, delivered in the end of October, now has this problem. Sometimes when I start it, the engine has a lumpy idle and sounds like it is about to die. I'm not sure if this is related also, but I've also noticed that the car is more hesitant when starting(i.e. - it is taking longer). It just passed it's 7000 mile mark. Any other '06s have this problem?
Picked up my 2006 MCSC Feb. 10 2006, now have cold starting problem two days in a row. I have about 5500 miles. I was freakin out with the dragon next week, but I at least feel better that it's not a serious problem. Still, never had such a new car with this kind of problem
Old Apr 30, 2006 | 06:54 AM
  #281
OmToast's Avatar
OmToast
Wow... so it's still a problem with the new ones? Good job, MINIUSA
My '03 MCS with 57K STILL needs to be cranked twice at times -- after many, many reflashes. I probably posted this earlier (say around page 5 or 6 ) but the problem for me tends to be temperature related. It seems that some sort of voodoo takes hold on damp-ish mornings around 50 degrees or so.
Aside from general neighborhood embarassment, it hasn't caused any problems with my car -- so I wouldn't worry. I think I've officially accepted it as a "characteristic".
Kinda funny that it's still an issue...
Old Apr 30, 2006 | 07:12 AM
  #282
snooter's Avatar
snooter
Mr. MOTD
And my wife thinks I have a strange sense of humor
Old Apr 30, 2006 | 07:21 AM
  #283
azuul's Avatar
azuul
Originally Posted by Bilbo-Baggins
Apparently MINI has solved the problem. My '02 MCS used to do the cold start/stutter/yo-yo/whatever but only after BMW/MINI installed mandatory emissions upgrade to the ECU, after assuring me that it would not cause these issues and informing me that I had NO CHOICE but to have the upgrade installed. Talked about one pi**ed-off customer
Same issue with my '03. I had no problems at all until I had to have the emissions upgrade. Now I have to start twice in the morning and also I have the big hesitation until its warmed up.:impatient
Old Apr 30, 2006 | 07:23 AM
  #284
JWM's Avatar
JWM
Stalling
This is still an issue with my "05". It started up again as soon as the Temp warmed up. Tarzan had his "05" in last Fall for some extensive service on this. The dealer said there was some fuel excess issue but I do not believe there was a fix.
Old Apr 30, 2006 | 08:57 AM
  #285
OmToast's Avatar
OmToast
My car has broadened my sense of humor considerably! :impatient
Old May 1, 2006 | 09:25 AM
  #286
defylogik's Avatar
defylogik
05 cooper has this problem occasionally. i noticed it only will happen on a tank of gas below half way. i also noticed that it takes a few more cranks to start it below half a tank.
i always thought this was just a way for the car to warn you that you are going to be getting more gas soon. hondas always did this, everyone i have driven. i am sure its the fuel pump working harder with lower gas in the tank.
Old May 1, 2006 | 02:55 PM
  #287
redrocket's Avatar
redrocket
my car just started doing it but as defy said the couple times it did it it was near the quarter tank left mark. i just got off of an accord and never had this problem and its honda then again it was pretty new, personally as long as im not stranded and its not putting any major wear on the car i really dont care, ive learned just to give it a bit of gas at startup and it seems to make throughthe stall
Old May 2, 2006 | 04:54 PM
  #288
jcast1281's Avatar
jcast1281
cold start engine hesistation and rough idle
seem to have the same problem here '06 cooper s convertible picked it late dec '05 have about 5600 miles going to nearest dealership in Albq. this weeekend will post on what was done or not done.
Old May 4, 2006 | 01:56 PM
  #289
LordOfTheFlies's Avatar
LordOfTheFlies
This just started happening to my 04 MCS. It seems that I need to hold the key longer or else the car almost starts and then just coughs and dies.
If I crank again and hold, it's fine.
Weirdness.
Old May 4, 2006 | 02:09 PM
  #290
scooterboy's Avatar
scooterboy
I don't have to start mine twice, but it has been taking longer for the engine to "catch" for about a week now. I have an '03 MC BTW.
I was in for service tuesday and mentioned it to the service manager at my dealer. He nodded his head and said it was the summer gas formulation.
He also said that we're going to see a higher ethanol content in our gas and it could wreak havoc on the engine. He said that if too much moisture gets into the tank the ethanol can separate from the gas and congeal into a gloppy mess that will hose the engine.
Anyone else hear anything like this?
Old May 17, 2006 | 06:35 AM
  #291
rclements's Avatar
rclements
Iridium plugs helped my car too
The 'colder' plugs removed 99% of the rough idle / hestitation / stall symptoms. My toy is an 05 MCS with numerous mods.
regards
rob
Old May 17, 2006 | 06:39 AM
  #292
LordOfTheFlies
I've got Denso IK22's and this phenomenon just started happening recently.
Old May 17, 2006 | 06:58 AM
  #293
shankrabbit's Avatar
shankrabbit
regards
rob
I can agree on that one, although, I still occasionally get the rough start, the idles at stop lights and such are much more smoother.
Old May 18, 2006 | 05:57 AM
  #294
minifiniRnD's Avatar
minifiniRnD
i have an idea
hey guys i have a question has any one tried just leting there car warm up a bit before geting going because my 02 mini s has never done it.
what i mean by warm up in cold weather is you should wait till the temp needle at least moves just a little bit, in warm weather take a minute and let the car run if it stumbles just ideling give a little gas see ifit clears its self up
i am just a shade tree mechanic and from what i am reading (not having experienced this) that is what i would do
Old May 18, 2006 | 06:20 AM
  #295
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
Yep, mine does this too.
Old May 18, 2006 | 04:19 PM
  #296
pcnorton's Avatar
pcnorton
You don't understand the problem. On initial start up it wont stay running to get a chance to warm up. It starts head to about 1000 rpm then stumbes and dies.
Paul
Old May 18, 2006 | 05:57 PM
  #297
PSYCMINI's Avatar
PSYCMINI
I now have this problem...my car is an 02 with 40k, i never had this problem till now...this is my first summer with the car, I guess it is a summertime thing.
Old May 20, 2006 | 05:34 PM
  #298
COOP310's Avatar
COOP310
I Just started having this problem on my 04 MCS about a week before the dragon. I made an appointment when I got home and the dealer tried a "brand new" software fix (version 44?. The very next day the problem was still there - stalling the first try after sitting a while, then starting on the second.
Old May 20, 2006 | 05:58 PM
  #299
BlueCooperS's Avatar
BlueCooperS
Putting in a Screamin' Demon coil stopped it for me.
Old May 20, 2006 | 07:23 PM
  #300
snoogie's Avatar
snoogie
Seems to only be a problem with the S model, not the Cooper.
