Is your car stalling upon starting?
Old Sep 14, 2005 | 09:54 AM
  #226
1FSTMINI's Avatar
1FSTMINI
Originally Posted by SHUMopper
My fiance has this problem with her Mini S (2004) with 37K miles. Its done it since the time she has had it with numerous ECU updates and no resolve.
I decided to upgrade her spark plugs to set of Denzo Iridium's and it seemed to help out the problem a good amount. Only the occasional stall now. But its definetly better.
Which dealer do you go to?
Old Sep 14, 2005 | 10:07 AM
  #227
blue agave's Avatar
blue agave
Originally Posted by Pat_Cooper
This has become like a MINI flu. Alot of people on NEMINI.org have been complaining about this and well..there hasn't been one dealer yet to fix this issue. The problem mainly occurs after the car has been sitting for a long time and when you go to start it, it starts to choke up and stall. If you are having this issue please post about it. I'd like to take this thread and forward it to MINIUSA directly.
I originally thought it was just the 2005 models but my friend with a 2003 is now having the same issue aswell.
Also, can a moderator please sticky this if possible. Thank you!
I also have thisd issue in a 2003 JCW. I just got the car in March and the problem didn't arise until May. Some site postings suggest it is the summer gas reformulation. I know this thread may be going to BMW, but my personal opinion is that this is an imperfection in the operation of the vehicle, but it is harmless, takes one more turn of the ignition key to correct and in my garage, there is no one there to evoke my embarrassment
Old Sep 15, 2005 | 07:32 AM
  #228
lvbltec's Avatar
lvbltec
yeah um try agian all u did if anything was reset the cluster
Originally Posted by pmello
I was having starting issues the past 3 weeks. I reset the ECU via using the software method (ignition / milage-clock reset button). Search for ECU reset. It seemed to work this morning, but I can't tell for sure as it finally warmed up to 60deg's today!!!
Old Sep 15, 2005 | 07:59 AM
  #229
1FSTMINI's Avatar
1FSTMINI
You can only clear your adaptations thru a GT1 machine. Clearing it wont make a difference though being the system is adaptive and is always re-learning itslef everytime you drive. Only time to do this , is when you get a fault code.
Old Sep 16, 2005 | 09:17 AM
  #230
lvbltec's Avatar
lvbltec
what r u talking about that makes no sence
Old Sep 16, 2005 | 10:25 AM
  #231
1FSTMINI's Avatar
1FSTMINI
n/m
You guys keep tryin to do what your doing. Good luck!
Old Sep 16, 2005 | 12:44 PM
  #232
mdavis's Avatar
mdavis
My MINI as well
I have a 2005 MCS that has ALWAYS had the stall on start problem and it's been both annoying and embarassing. It happens when I start the car in the morning, and at the end of the workday at times.
The other really concerning issue is a throttle hesitation about 30 seconds after start. I happen to need to make a left turn onto a large road at that time and the car has put me in a dangerous position because of this hesitation.
Has anyone contacted the major car magazines? I suspect the best way to bring on change is to get their attention.
Best- Mark, Portland, Oregon
Old Sep 20, 2005 | 08:00 PM
  #233
MiniMe05's Avatar
MiniMe05
Our MCSa has this lovely feature as well. Runs like crap after sitting over night. Major throttle delay until fully up to operating temp. Very leary about pulling out into traffic. 2-3 second delay from prssing the pedal until anything actually happens. Once fully warm the throttle is good to go.
Old Sep 21, 2005 | 07:29 PM
  #234
husker1's Avatar
husker1
Stumble
Have any of you tried the VGS modification? It helped my '04 MCS.
Old Sep 24, 2005 | 07:29 AM
  #235
lvbltec's Avatar
lvbltec
the reason that they have not fixed this yet is because federal carb standards require that the set up the emissions a certian way and that is what is causing the "programing issue" fir the stall at first starting and the rough running at idle
Old Sep 24, 2005 | 11:38 AM
  #236
blalor's Avatar
blalor
That's not an excuse. I'm betting BMWs don't have this problem!
Old Sep 24, 2005 | 03:54 PM
  #237
Thameth's Avatar
Thameth
Yea but they don't have any SuperCharged 4 cylinders in thier line up...
Old Sep 24, 2005 | 04:08 PM
  #238
gokartride's Avatar
gokartride
'03 Cooper...not a problem, thankfully.
Old Sep 24, 2005 | 04:13 PM
  #239
Thameth's Avatar
Thameth
Its pretty much an MCS problem....
Old Sep 24, 2005 | 06:45 PM
  #240
Yellow_mini's Avatar
Yellow_mini
my '05 MCS does this when if first turn it on the RPM's drop and raise (stumble) but once i put it in 1st and start rolling there are no other problems.
Old Sep 26, 2005 | 01:55 PM
  #241
darkfact's Avatar
darkfact
I've got this lovely problem w/ my '04 MCS too. I get the stalling problem the first time I go to start it after it's been sitting and then it has major hesitation while driving for about the first 10-15 minutes of driving. I've had a few times where I pulled out of an intersection and felt like I was going to get hit because the throttle just fell completely flat. When I first got my MCS (April '04 build) all I had was the occasional rough idle issue. They updated the ecu back in like March to I believe v.40. The car ran great for the first couple days but after that just went to crap. According to the dealer here in Portland, Supposedly they had some MINI folks going around to various dealers to investigate this issue a couple months ago. I've been checking w/ the dealer periodically, but still no fix as of yet that I'm aware of....
Old Sep 30, 2005 | 01:56 PM
  #242
PDX_Mini's Avatar
PDX_Mini
Stumbling/stalling and warranty question.
My '03 S has stumbled on and off since I bought it. A new or reverted software version would fix the issue temporarily but it would steadlily get worse and then I would go back in. Since September of this year, after I had my 30k service, it has run worse then ever. If the car sits for more than a few hours I have to warm it up for a few minutes or it will stall. The first few times I pull away from a stop after I start driving I have to ride the hell out of the clutch to keep the RPM's from dropping below 1000 and leaving me starnded in the middle of the street (my wife refuses to drive it any more as it has left her looking down the path of a large truck one too many times with the accelerator on the floor and the car motionless). My dealer said they cannot do anything about it. I called MINI USA and they said 'what a terible thing' but there's nothing they can do. I want to sell the car but doubt I could do it with the way it's running. Has anyone pursued any action against MINI or their dealer from this issue?
Nate
Old Sep 30, 2005 | 02:15 PM
  #243
eMINI's Avatar
eMINI
Took this from post #183 of this thread:
Originally Posted by sndwave
I disconnected the battery and reset the ECU when I was at the Dragon two weeks ago and then drove the cr@p out of it for about 5 miles and it seems to have done the trick for the stalling problem. It still lacks the off the line power the v32 gave me, but I’ll live with this until I get a pulley and chip in a few more months.
Give this a shot and see whether it helps. I'm beginning to suspect that it's a bug in the software that is aggravated by the learning adaptive nature of the ECU. That may be why it's OK for a while after new versions are installed and then gradually returns. Maybe our MCS is trying to tell us to drive harder
Old Sep 30, 2005 | 02:31 PM
  #244
KarenTKD's Avatar
KarenTKD
My '05 MCS seems to have a slight variation of this stutter problem. I've had the car for one month, with this issues popping up in the last two weeks, particularly on the colder mornings. When I first start the car in the morning, I get a rough, jerky, vaguely stuttery shift between gears. It's like the car just woke up and is still yawning. After I've shifted up through all of the gears once, it's like the car wakes up, and all further shifts are smooth and even. If this is the worst of it, I can deal. :smile:
Old Oct 1, 2005 | 06:10 AM
  #245
1FSTMINI's Avatar
1FSTMINI
Originally Posted by KarenTKD
I get a rough, jerky, vaguely stuttery shift between gears. It's like the car just woke up and is still yawning. :smile:
I printed this out and put it up on the bulletin board in the shop....Thats priceless.
Old Oct 1, 2005 | 03:43 PM
  #246
Thameth's Avatar
Thameth
Hahaha i like it too, its kind of funny. The whole morning studder thing hasn't affected driving i just know to putter around my complex to let her warm up as i leave in the morning. In a way it gives the car a bit of character kind of like a nasty built up race car or something hehehe. Takes a little bit to get her up and awake in the morning haha.
Though if they can fix it in an ECU update i would.....
Old Oct 1, 2005 | 05:54 PM
  #247
MiniMe05's Avatar
MiniMe05
Parked the Mini in the garage last night. This morning wifey jumps in to run some errands. I hear the door go up and shortly there after she comes. Hun come listen to the car. I go out and the car is idling on 2-3 cylinders. I press the throttle and it revs to about 1200 rpm. No more. Floor it noting. Check engine light comes on. Turn it off sit about 30 seconds and restart. Idles ok and revs normal. Check engine still on. Of course the dealer service is not open Saturdays so we will have to wait until Monday to see when they will have time to get it in. This is round two for us. New software not so good.
Old Oct 1, 2005 | 05:59 PM
  #248
pcnorton's Avatar
pcnorton
I really find it hard to believe this a programming thing and not a air in the fuel system thing.
Programming would make it happen all the time unless ther is a line of code that (forgive me, last I programmed was in the early 80's):
10: If rnd(a)>.5 then starve fuel on start up then runnormal
Paul
Old Oct 1, 2005 | 09:51 PM
  #249
Thameth's Avatar
Thameth
Paul
It happens ALL the time for me on cold starts, its easily repeatable if i let the car site for at least 5 hours. Even if the car sits outside in 90 deg heat it'll still stumble twice in the first minute and then level out.
Old Oct 3, 2005 | 12:50 PM
  #250
MiniMe05's Avatar
MiniMe05
I have been on the phone to the Portland Mini dealer this morning. They are trying to tell there is nothing wrong with the car. They claim it runs poorly when cold because of bad fuel. Their suggested fix is to start running regular 87oct unleaded. Nice fix. I asked them to send that to me in writing but they refused. I can tell this is going to be fun. Also they won't be able to get the car in for another week. No loaner cars available. So we have to nurse the car for a week and hope it makes it. We are rapidly getting disinchanted with the Mini.
