is my cylinder head still usable?
Old Apr 29, 2022 | 08:29 AM
frankiev's Avatar
frankiev
R53 long story short.
I Installed a rebuilt cylinder head and shortly after that the engine locked up and sent tiny bits of metal through my baby . I recently picked up a used engine that has an obvious valve stem oil seal leaking in cylinder 4 exhaust . I'm thinking I'd rather use the rebuilt head if it's still usable .
Here are some pics if the cam and upper and lower journals . Scratches on lower and cam seem to be superficial . Can someone with more knowledge than me please advise
Lower
Cam
Upper , discolored but don't feel like high spots
Old Apr 29, 2022 | 09:21 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Nope. Looks like oil starvation. You install a new cam. Going to do the same thing.
Old Apr 29, 2022 | 10:14 AM
frankiev's Avatar
frankiev
I see . So heads toast . 🥺
Old Apr 29, 2022 | 10:29 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
No the head is no good. The journal’s are bad. If you put in a new cam. It going to tear up the cam. You may want to inspect the rod bearings. I think you are going to find them in the same condition. Along with the mains.
Old Apr 29, 2022 | 10:31 AM
frankiev's Avatar
frankiev
Engines locked up solid so bottom end is trash
Old Apr 29, 2022 | 10:33 AM
frankiev's Avatar
frankiev
So i guess im using the head on the engine i bought . By any chance do you know of a valve spring compressor that I can use to change the valve stem seal without removing the head
Old Apr 29, 2022 | 10:43 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Nope. Have to remove the head.
Old Apr 29, 2022 | 11:21 AM
frankiev's Avatar
frankiev
This looks like it might work . What do you think. 50$ on amazon
Old Apr 29, 2022 | 01:07 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
The valve will fall into the cylinder.
Old Apr 29, 2022 | 01:40 PM
Nervos's Avatar
Nervos
It looks pretty bad on pictures, but! I'd try to polish both - cam journals and cam seats / caps and would measure the gap using plastigauge. If it is way out of spec - then yeah, it is a waste. Note, it is kinda fine to have some groves on seats/caps and cam journals; the main target for polishing is to remove any protruding material, which will scratch the mating surface.
Old Apr 29, 2022 | 01:47 PM
frankiev's Avatar
frankiev
Sounds like a good plan . Thanks. Any suggestion on how to go about polishing it .
Old Apr 30, 2022 | 04:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The trick is to coil rope into the cylinder through the spark plug hole, then turn the crank to lift the rope into the valves. Then use the tool and the valve stays put.
keineth Ewell
Jul 17, 2022 06:54 AM
OCR
Sep 4, 2018 07:24 AM
tech12
Sep 16, 2015 05:30 PM
MJohnson81
Want to Buy - All Other Items (archive)
Mar 1, 2008 04:42 AM
SteveS
Mar 16, 2005 05:23 PM
