Gouged cylinder wall and head repairable?
Old Jun 30, 2021 | 09:41 PM
keineth Ewell's Avatar
keineth Ewell
I just got a 2007 HT base "justa" r56 n12. New to mini coopers but very mechanically inclined. Never rebuilt an engine tho. Was supposed to be just timing but found a shattered piston, deep gouges in cylinder wall, and a beat up head around the valves for 1 cylinder. What's my best course of action.? The gouges in cylinder wall are deep. Can it be saved with a rebore? Get new block and swap internals? Tia
Old Jul 1, 2021 | 06:31 PM
yeticat99's Avatar
yeticat99
I think I'd be shopping for a new engine if I were in your shoes. The block and head might possibly be salvageable by a good machine shop, but it seems likely your crankshaft also would have suffered a significant amount of stress until all those bits of piston found their way to the oil pan.
I spent $455 on getting my N14 block bored 0.5mm over with one cylinder getting a dry sleeve. Add new pistons, bearings, stretch bolts, etc. and you're in over a grand just on the block. The costs of a rebuild can add up quick - easily exceeding the value of the car. Good luck!
Old Jul 2, 2021 | 12:01 PM
thefarside's Avatar
thefarside
Better pics showing the extent of the bore damage would be helpful
What yeticat99 said!
Old Jul 17, 2022 | 06:54 AM
gimmea250swb's Avatar
gimmea250swb
Well, it's been 500 miles since I completed my rebuild. It took ~5-6 months all told (from diagnosis to turn key). Only a few left over screws. You can see the other related posts, but during rebuild, I replaced the flywheel and clutch in addition to all the block internals. I've effectively got a new car now. I just wanted to close this one out to send a thank you to the team!
https://www.northamericanmotoring.co...r-leaking.html
https://www.northamericanmotoring.co...ar-intake.html
Andernamen
Feb 8, 2020 05:44 AM
DiggyDog
Jul 2, 2015 04:24 PM
D-MAN
Feb 28, 2008 05:59 PM
