Airbox Bolts
Old Feb 8, 2020 | 05:05 AM
m1n1mee98's Avatar
m1n1mee98
Airbox Bolts
So, I noticed that the airbox didn't have any bolts holding it down. The previous owner must have lost them or forgot to put them back in. I was wondering what bolt it uses to secure it so I can go get some from the hardware store.
It has also left a big gap between the filter and the top of the airbox. My mini is throwing a P1498 code and seems to be running pretty rich, could this be the cause of it?
Old Feb 8, 2020 | 06:35 AM
ssoliman's Avatar
ssoliman
Realoem.com
punch in last 7 of vin
Old Feb 8, 2020 | 06:38 AM
ssoliman's Avatar
ssoliman
Don’t think that will cause rich condition. Maybe dirt in the intake.
maybe got map sensor dirty
Old Feb 17, 2020 | 12:10 PM
m1n1mee98's Avatar
m1n1mee98
What is a normal MAP sensor reading? Mine is reading around 10 psi at idle.
Old Feb 17, 2020 | 03:18 PM
ssoliman's Avatar
ssoliman
what is your idle at temp? I’d have to check with inpa
Old Feb 17, 2020 | 03:36 PM
m1n1mee98's Avatar
m1n1mee98
It sits around 750 rpm, but it seems to have a slightly rough idle. Not enough to stall the engine or anything, but it's noticeable. Almost like a random cylinder misfire.
I also just back probed the MAP sensor on the intake manifold. I used a DMM to get the voltage across the signal wire and ground. What I found was that at idle, it would sit at around 1.0-1.2V, when the throttle was pressed it would drop. So it seems to be functioning correctly.
Old Feb 17, 2020 | 05:14 PM
Getn off's Avatar
Getn off
I have found nearly all of mine are stripped out. Only one holding it together and I aint coughing up the dough for a new one.
Troy
Old Feb 17, 2020 | 05:16 PM
m1n1mee98's Avatar
m1n1mee98
I just got some M3x45mm bolts and lock nuts from the hardware store. Only cost $3
Old Feb 18, 2020 | 05:28 PM
ssoliman's Avatar
ssoliman
my maf hovers around 9.00 in inpa @ 750 rpm. But it’s measured in kg/sec not psi. Measure of air flow
about 27 kg/sec @3000 rpm
Old Feb 19, 2020 | 08:16 AM
m1n1mee98's Avatar
m1n1mee98
I picked up some carb cleaner and noticed when I sprayed it near cylinder 1 injector the engine would stutter. I also noticed a slight hissing sound when I got my ear close to it.
So when I find time I'm going to pull off the intercooler and look around. I'm thinking it could be a bad injector O-ring or a bad manifold gasket.
s29_myk
24
Jun 18, 2016 08:01 PM
toyopet
Tires, Wheels, & Brakes
May 10, 2016 07:47 AM
idickers
Dec 5, 2014 04:45 PM
tummi_gummi
Apr 14, 2014 05:39 AM
dazzo
Apr 23, 2005 07:46 AM
