Slow slapping tapping goes up slightly with rpm
Old Nov 15, 2019 | 07:08 PM
7thmoosefromtheleft's Avatar
7thmoosefromtheleft
Went to start my 2011 mcs this morning and heard a wonderful noise comming from my engine rythmic slapping.
While I'm sure it part put time I figured I'd get your thoughts before hand
Video
Any thoughts would be nice
Old Nov 15, 2019 | 09:04 PM
MiniToBe's Avatar
MiniToBe
Check out the serpentine belt.
Old Nov 15, 2019 | 09:07 PM
7thmoosefromtheleft
Short of a car left and/or taking the wheel off how does one go about doing that
Old Nov 15, 2019 | 09:11 PM
MiniToBe's Avatar
MiniToBe
Look at the inside of the belt. Sometimes small chunks go missing from wear and tear. Just remove the wheel and spin the engine by hand, 18mm socket clock wise.
Old Nov 16, 2019 | 09:25 AM
Lancaster's Avatar
Lancaster
I would use a stethoscope to identify from where the noise is originating. Have you replaced your timing chain tensioner? Mine was loose and leaking oil significantly. The engine was considerably quieter after I tightened it. That said, it could be so many different items.
Old Nov 16, 2019 | 10:22 PM
7thmoosefromtheleft
Where did the oil collect I do have an oil leak, was not significant enough to fix, I used about a bottle every ou lb change
We thought it was the rear main seal
Old Nov 17, 2019 | 03:18 PM
Lancaster's Avatar
Lancaster
It would run all the way down from the tensioner bolt by the intake manifold to the oil pan. I thought my oil pan seal we bad.
Old Nov 20, 2019 | 06:24 PM
7thmoosefromtheleft
I'm pretty sure it's actually a rod knocking. So it's time to try to get what I can out of it
Shop will confirm tomorrow
Old Nov 21, 2019 | 10:11 AM
7thmoosefromtheleft
it would appear oil leak caused the belt tensioner to malfuntion belt slap was in fact the cause
car was driven 5 miles w/o oil cap so might not even be a leak
cavaliers60
Aug 30, 2018 07:06 PM
piotrus22
Dec 4, 2015 10:31 AM
shub
Feb 13, 2015 10:18 PM
jamalz
Sep 29, 2014 09:40 AM
burnsmt
Oct 11, 2013 05:59 AM
