PCV Problem
PCV Problem
Hey guys, have a problem with what I believe is the PCV system. The hose connecting to the back of the valve cover is collapsed and when I open the engine cap there is a clear vacuum. (The tube is no longer collapsed once the cap is opened)
I believe this means the PCV itself is broken and allowing air to freely pass through. I’m looking at a new valvecover I’m assuming?
I need to go for a pretty long drive next weekend (500 miles or so) and doubt I’ll get the valvecover here in time. Do I have any options other than wait?
ECS Tuning has N14 valve covers in stock. I would think they could get you one pretty quick....
https://www.ecstuning.com/Search/Sit...h/11127646555/
The N14 has a separate PCV value doesn't it? Why do you need a new valve cover for the PCV valve? Also, I think they make PCV repair kits now...at least for mine which is N18 (2011), they do.
https://www.amazon.com/Valve-Cover-Membrane-Cooper-Engine/dp/B07TCKQY8Y/ref=sr_1_3?keywords=N18+pcv+membrane+repair&qid=1572734637&s=automotive&sr=1-3
What car and year do you have?
The N14 has a separate PCV value doesn't it? Why do you need a new valve cover for the PCV valve? Also, I think they make PCV repair kits now...at least for mine which is N18 (2011), they do. https://www.amazon.com/Valve-Cover-M...omotive&sr=1-3
What is the N54 in the post of your subject? LIke I said, I have no idea what car or year you have. I think maybe you have to start with that. If you have a PCV on your cover, there is a round thing on the top of your cover. If you have a line coming out the back, the PCV could be on that line.
https://www.motoringalliance.com/art...gine-codes.46/
its a 2009 MCS with the N14 engine.
You can buy these now "without" buying the whole valve cover. Here is an N14, $30
https://www.youtube.com/watch?v=X9wMakj4qNU
You have to love these cars.
I think they show testing it in this post.
https://www.northamericanmotoring.co...ry-solved.html
Thank goodness they changed this in my car....
Yep. Looking at this thread...https://www.northamericanmotoring.co...pcv-valve.html
Maybe someone took the cover off, cleaned it, cut open the cover, put a new one in and glued it back. JB-Weld.
I would say you would have a 40% chance of that working. Not wise on a huge trip and in the middle of no where either.
Or, maybe just just cleaned it and got it working again.
frozenwaffles
Jun 30, 2019 05:42 PM
Mini Cooper hell
Sep 4, 2018 12:52 PM
ig109
Mar 21, 2018 06:06 AM
