Replacing VANOS Solenoids and Chain Tensioner
Old Mar 17, 2019 | 02:40 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I am looking at the task of replacing my VANOS solenoids, and possibly the timing chain tensioner.
Question: When replacing the timing chain tensioner, how important is the step of pinning the flywheel? If I am only pulling and replacing the tensioner, what are the chances of the chain jumping a tooth? It seems to me that there shouldn’t be that much slack in the chain so that it would be that prone to jumping a tooth...
Old Mar 17, 2019 | 06:25 PM
CantComplain's Avatar
CantComplain
just trying to come at this with a perspective based on logic, I agree with you. It will definitely not jump a tooth anywhere: it would be impossible unless you were turning the engine over somehow. The pin in the flywheel is part of the timing process but this is just a subset of that work and shouldn't need it. That would be my vote anyway.
Let us know what you decide and how it goes.
edit: I'm assuming by solenoid you mean the actual cylindrical solenoid with the sludge strainer in the head and not the VANOS device on the CAM(s). THAT would definitely trigger the full timing sequence including the flywheel
Old Mar 18, 2019 | 03:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes, the oil control solenoids, not the cam actuators.
I figured for the tensioner, just pull the old one out, stick the new on in, and be done. But, if I have to lift the car, find the timing mark on the flywheel, lock it, then pull the tensioner, it will add much more to the job than might be needed.
Old Mar 18, 2019 | 01:11 PM
Yupetc's Avatar
Yupetc
Absolutely no need to set the flywheel pin in if all your'e doing is replacing the tensioner. Those cams and crank will stay in place quite well unless you actually mechanically try to move them while the chain is loose. The direction of the force isn't applicable towards moving the cams nor the crank in this case.
Old Mar 18, 2019 | 01:16 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Thanks! Makes me feel a little better about what I want to do.
Satsloader
Sep 18, 2020 04:51 AM
bond_007
Jul 19, 2017 06:57 PM
ONEBUNCHMIN
Sep 28, 2016 02:34 PM
gbfan10
23
Dec 12, 2012 08:26 PM
