Oil Change Service Reminder Will Not Reset
Old Mar 17, 2019 | 07:38 AM
newbaycolony's Avatar
newbaycolony
As the title states, my oil change reminder will not reset. I have tried all the combinations of key positions and trip odometer button pushes. I never see the "Reset" screen only the "Test" screen. I can do all the tests, but not do a reset. I purchased a scan tool for MINI/BMW and it will read all the sensors, clear all the codes but it says it can't connect with the reset function. If there is a thread on the forum that addresses this issue, please point me to it. Other suggestions are appreciated. Thanks in advance.
Old Mar 17, 2019 | 08:07 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Originally Posted by newbaycolony
...my oil change reminder will not reset. I have tried all the combinations of key positions and trip odometer button pushes. I never see the "Reset" screen only the "Test" screen. I can do all the tests, but not do a reset. I purchased a scan tool for MINI/BMW and it will read all the sensors, clear all the codes but it says it can't connect with the reset function. If there is a thread on the forum that addresses this issue, please point me to it.
If the oil service light has recently been reset, you need to travel at least 20% of the mileage (3100 miles) towards the next service interval before the system will allow another reset. Trying to reset before that will not work.
To RESET Oil/Inspection Service:
Press and hold the trip odometer button.
Insert car key and turn it to the first position.
You will see 51A come up in the trip odometer area.
Release, then press and hold again.
Watch for the word RST to appear on the Odometer indicator.
Wait for the RST message to flash.
Release, and then press and release (once only).
The Service interval is now reset to 15,500 miles.
Old Mar 17, 2019 | 08:49 AM
newbaycolony
I never see the anything but "Test" No "51a" or "Reset"
Old Mar 17, 2019 | 08:50 AM
Capt_bj's Avatar
Capt_bj
IME this 'timing' between the various button press' can be very finicky
usually took me 4 or 5 tries before it 'took'
Old Mar 17, 2019 | 08:58 AM
newbaycolony
I think I've done it at least 15 times 4 different ways.
AMink
Feb 26, 2012 12:51 PM
sassiegyrl
Jun 29, 2011 01:48 PM
yamsandclams
Oct 7, 2010 05:45 AM
jrprich
Nov 30, 2009 06:13 PM
grimmdj
Oct 6, 2003 07:25 PM
