2008 Cooper S 123k miles starts then dies
Old Feb 21, 2019 | 12:16 PM
tsa1's Avatar
tsa1
My car will crank and "start" then it will die. There is no CEL's being thrown.
The only problem I know it currently has is a cracked PCV hose. Would that cause this issue?
The HPFP was replaced about 5k miles ago at the dealer along with the fuel line. But no CEL's so i don't think it's that. I also replaced two of the coil packs with OEM's form ECS to match the other OEM packs.
My valve cover is starting to go as i see slight oil seepage.
Thanks in advance!
Old Feb 21, 2019 | 01:10 PM
Does it sound like its missing or rough idle when it runs?
Old Feb 21, 2019 | 06:07 PM
RockC's Avatar
RockC
Long shot but I ran into this behavior years ago with a brother in law's new Toyota Corolla something or other.
Long story short the problem proved to be a bad fuse. There was a fuse on the engine start circuit -- which was fine -- and a fuse on a separate engine run circuit. The fuse on the engine run circuit was bad. No electrical problem the fuse just died prematurely because after replacing the fuse the engine fired right up and ran just fine and the fuse never failed after that.
Old Feb 22, 2019 | 12:07 PM
tsa1's Avatar
tsa1
Rough idle then dies. I've been able to keep it running by giving it some gas.
Old Feb 22, 2019 | 12:08 PM
tsa1's Avatar
tsa1
I will look into this! thank you! I did recently jump the car because it had sat for too long. Perhaps this may be related. I will check the fuses!
Old Feb 22, 2019 | 12:11 PM
Check your electrical connections, then fuel and if the HPFP has a fault, if not swap the coils and see if the plugs are full of gas and not firing, you might have the other coils bad.
Old Feb 22, 2019 | 12:45 PM
vaios's Avatar
vaios
The problem is HPFP. Check youtube videos.
I hope I helped
Rat Garage Works
Greece
Vaios
Old Feb 22, 2019 | 12:47 PM
tsa1's Avatar
tsa1
I will check them! there are no faults other than some air mass sensor plausibility and unmetered air faults.
I do get an exclamation mark on the driver side display when it shuts off but not half power or cel.
Old Apr 30, 2019 | 11:28 PM
tsa1's Avatar
tsa1
UPDATE! I think my fuel pump was just seized up because it stated running ok once i gave it gas and held it at around 1500-1800 RPM. It did display the common symptoms but the fuel pump was replaced under recall at 119K about 2 years ago and only has around 4-5k miles on it. (i don't drive it alot).
THEN! I knew my pcv hose was cracked, but I did not know how much of a difference it made. Once I replaced that (which ended up being rather easy, just intimidating at first). No one CEL's and passed smog well. I did get another CEL earlier tonight for MAP or mass airflow sensor/ unmetered air, but I'm hoping it just needs some cleaning. It has been running well for the past 5 days and still did despite the CEL.
Now i have to figure out why my AC isn't blowing cold air. Compressor engages, but i have a hollow sound coming from the vents and center console (it sounds like a leak). Haven't checked if this is the case but we shall see.
Thanks to everyone for their help!
Helltime
Jan 21, 2020 01:11 PM
adamseg
Dec 15, 2013 09:02 AM
FEEL
Oct 2, 2013 04:26 PM
BLavin
Dec 11, 2011 07:23 AM
ITALNJOB84
Apr 29, 2009 01:57 PM
