2005 Mini starts then dies
Old Nov 8, 2013 | 02:02 PM
adamseg's Avatar
adamseg
105K miles My girlfriends' 2005 mini starts, idles for a moment and then dies. When I give it gas while starting it gets really rough before dying. and the same when I wait to give it gas after it starts? Thoughts? What would be the easiest way to diagnose the problem? What is most likely the culprit? I am unaware of what common issues may occur with this vehicle.
Old Nov 8, 2013 | 02:03 PM
adamseg's Avatar
adamseg
as far as I know, there was no indication that this was going to happen- no known issues prior to this event.
Old Nov 8, 2013 | 02:23 PM
Nitro Jake's Avatar
Nitro Jake
Take it to a mechanic
Old Nov 8, 2013 | 02:24 PM
BlwnAway's Avatar
BlwnAway
With no more info than this & the milage on the car, best guess is beginings of a map sensor failure, again just quick guess.
See if you can force it to stay running by playing with the throttle pedal, maybe it'll throw a code for you.
Old Nov 8, 2013 | 02:34 PM
Nitro Jake's Avatar
Nitro Jake
^^this is also a great way to damage the catalytic converter if the car is misfiring. If the following advice does not make sense, please take my previous advice:
If the car is driving/idling/running poorly, do not drive it anymore until the problem is resolved.
First check for trouble codes and consult your manual and/or look it up on the internet.
If misfire code(s) exist, check ignition track for failed coil, wires, and/or plugs. if all is good, then next easiest thing to do is a compression test. If that fails, you've got engine problems- most likely burned exhaust valve or damaged piston rings. if compression check passes, check fuel track for fuel pressure and/or injector failure.
Old Nov 9, 2013 | 03:06 PM
minsanity's Avatar
minsanity
Check your fuel pressure by hooking a gauge on the fuel rail schrader valve under the intercooler if it's an S. 40+psi for an R50, 50+psi for a 53. If way below, fuel pump maybe suspect.
Old Dec 15, 2013 | 09:02 AM
VKV's Avatar
VKV
Did you figure out what was wrong with 2005,105K Mini that started than died? This happened to my 2005 Mini 99K, 12/13/2013. It had to be towed to mechanic last Friday afternoon. It finally started at the mechanic shop with a strong gas/exhaust smell.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
mdutton11
14
Oct 26, 2015 01:47 PM
bc219
Aug 10, 2015 11:22 AM
