Cold weather alert chimes, will not STFU!
Old Dec 28, 2018 | 05:27 PM
wesmc's Avatar
wesmc
This is driving me crazy. If the temp is low enough to trigger the chime and message on the dash it just keeps doing it randomly the entire trip. It's like chinese water torture. Is there a way to silence it?
Old Dec 29, 2018 | 06:52 AM
cyberlunacy's Avatar
cyberlunacy
do you mean its not only when you start the car, like it wont stop chiming even when driving?
Old Dec 29, 2018 | 07:44 AM
chrunck's Avatar
chrunck
I don't know if it helps to know what triggers it, but it will go off every time the temperature hits 37 degrees. So if the outside temp keeps fluctuating between 38 and 37, you'll hear it a lot.
There's no way to disable it as far as I know. Maybe with some advanced programming, but that's outside my knowledge.
Old Dec 29, 2018 | 08:47 AM
Minidogger's Avatar
Minidogger
Mine is annoying too, but only chimes once per start.
Old Dec 29, 2018 | 01:07 PM
wesmc's Avatar
wesmc
Mine seems to be random. Its in the 20s here now and it goes off at start, then randomly as I drive. Seems to be worse when driving slowly, less frequent on the highway.
Old Dec 29, 2018 | 01:08 PM
MrGrumpy's Avatar
MrGrumpy
Yep, it sounds like the temp is just varying between the trigger temp and a little warmer, so it keeps going off. Mine will do this too if the temp goes up, every time it hits 37 degrees it will chime the gong! Lol. Usually it only happens once or twice but it’s up to the weather.
Old Dec 29, 2018 | 01:15 PM
Capt_bj's Avatar
Capt_bj
move to Florida
problem solved <for the most part>
Old Dec 29, 2018 | 02:42 PM
MrGrumpy's Avatar
MrGrumpy
That’ll do it
Old Jan 7, 2019 | 03:52 PM
sawicki's Avatar
sawicki
The trigger is 37 degrees F. I work second shift and on my trip home if its around the 35-40 degree mark ill hear the chime when i fire it up, then again when i go down through a tunnel then again when i cross the bridge. Once it either warms up or steadily bellow 37 you wont hear it except for start up.
twistertime36@gmail.com
Nov 5, 2015 01:56 AM
mrbug
R57 :: Cabrio Talk (2009+)
Jul 11, 2015 11:42 AM
fmalgapo
Aug 5, 2013 05:26 PM
ANT818
Jun 8, 2008 07:10 PM
gokartride
Feb 12, 2008 05:54 PM
