While I'm in there . . .
Old Jun 19, 2018 | 05:31 PM
JAB 67's Avatar
JAB 67
I'm about to replace the passenger side axle on my 2004 MCS with 155K. Am I correct that it would be demonstrably easier to change the oil cooler gaskets while I have the axle out? TIA.
Old Jun 19, 2018 | 08:09 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the oil filter housing to block gasket is really easy to change with the axle out.
https://www.waymotorworks.com/oil-fi...0-r52-r53.html
You can also do the cooler lines
https://www.waymotorworks.com/oil-co...s-r52-r53.html
Old Jun 19, 2018 | 08:31 PM
AoxoMoxoA's Avatar
AoxoMoxoA
With the axle out, it will aid the process of removing the oil filter housing and replacing the gasket from housing to block. The two housing to oil cooler o-rings are best replaced via removing the cooler/heat exchanger from the filter housing through the passenger wheel well, so the axle being removed has no bearing on that.
FYI, if you’re replacing the axle, you might want to also replace the output shaft seal while you have it out.
Old Jun 20, 2018 | 12:50 AM
JAB 67's Avatar
JAB 67
Where is the ‘outer shaft seal?’ Hard to do? Need special tool?
Old Jun 20, 2018 | 03:43 AM
AoxoMoxoA's Avatar
AoxoMoxoA
It’s the “output” shaft seal, where the inboard splined end of the axle goes into the gearbox, and no, it’s not particularly difficult to replace. Just need a longish thin flathead screwdriver or prying tool to carefully pry it out. Old seals can be inflexible, and require a little more effort to get out.
Clean orifice well after seal has been removed.
New seal is lightly lubricated before being tapped evenly back into place and you’re done.
dmbmagic
May 1, 2017 08:05 AM
ACGOG
Nov 6, 2015 01:33 PM
afadeev
Apr 20, 2014 07:48 AM
Raiyu
Aug 17, 2011 11:19 PM
CARdiac
Dec 30, 2009 09:30 AM
