Drivetrain Getting ready to replace the clutch... what else should I do while I'm down there?
Old Nov 5, 2015 | 08:28 AM
ACGOG's Avatar
ACGOG
Hi, new to the forums.
Rewritten this a few times, trying not to be long winded.
I just found out today that the clutch needs to be replaced on my 2004 R53 JCW Mini. I'm not about to drop $2,300 to have it replaced by Mini as it's not my daily driver so it can stand to sit in my garage for a few weeks/months if necessary.
I'm planning on replacing it with the stock Valeo clutch (unless someone can recommend otherwise, but not the OSG.... too expensive):
Amazon.com: Valeo 52151203 Solid Flywheel Conversion Kit: Automotive Amazon.com: Valeo 52151203 Solid Flywheel Conversion Kit: Automotive
My question is though, while I have the car ripped apart, what else should I be replacing or looking at while I'm there?
2004 R53 JCW (some special edition that has 50th anniversary stickers on it)
104,000 miles
Recent work:
Valve gasket cover
Spark plugs
Distributor cap
Ignition coils
Cam/crankshaft sensors
Power steering lines
Thanks!
Old Nov 5, 2015 | 07:08 PM
Racingguy04's Avatar
Racingguy04
According to Pelican's website "When doing a clutch job, it's always a good idea to replace the rear end seal on the engine at the same time and also replace the throw-out bearing, flywheel bolts and pilot bearing. You should also replace the clutch release fork and the master/slave cylinders at the same time for added insurance. If you are re-using your flywheel, you should have it re-surfaced so your new clutch seats correctly."
Why are you going with a single mass flywheel? I don't have any first hand experience, but I've heard they're a bit noisy/rough if you bog the engine. I guess you do potentially get better throttle response/accelleration but I'm not sure that it's worth it to me.
Old Nov 6, 2015 | 06:00 AM
chris.j.lamb's Avatar
chris.j.lamb
Change supercharger oil
Replace crank sensor O ring
Old Nov 6, 2015 | 08:45 AM
Crank Seal and when you do the clutch the guide tube and seal on that should be replaced.
https://www.northamericanmotoring.co...-oil-leak.html 11111492244
Check the guide tube, most likely just replace it so the throw out bearing sides properly. And the seal behind it.
23117551719 Guide Tube
http://www.ecstuning.com/Search/SiteSearch/23117551719/ES42445/
and
Seal 23117518633
http://www.ecstuning.com/Search/SiteSearch/23117518633/
We also have the Valeo Single Mass Flywheel Conversion Kit 52151203 Right here:
https://www.ecstuning.com/Search/SiteSearch/52151203/
Great info here on Valeo Clutch:
https://www.northamericanmotoring.co...utch-disc.html
Old Nov 6, 2015 | 01:33 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 Yep! If you need anything, just let me know.
888.280.7799 | 6am - 5pm PST
Alpha Motoring
Nov 10, 2015 07:08 AM
vulkandino
Oct 31, 2015 08:29 PM
SJ-R50
Oct 28, 2015 08:39 AM
little egg
Oct 1, 2015 12:26 PM
Emnotek
Sep 29, 2015 07:37 AM
