Valve cover question
Old Apr 12, 2018 | 12:53 PM
Scooter24's Avatar
Scooter24
On on the back passenger side of my valve cover I'm getting a hissing sound. If i cup my hand around it I can make the sound quieter so I know it's coming from here. Does this part pop off so I can see whats under it? I'm guessing it pcv related but I wanted to ask before I start prying later.
Old Apr 12, 2018 | 02:03 PM
S-2013's Avatar
S-2013
The orange rubber diaphragm is more than likely torn underneath the round cover. You have two options here:
Replace just the diaphragm, (available on eBay) but risk breaking the tabs in the round cover, (arrow in your pic). Or...
Replace the entire valve cover which is what I eventually did after losing the new diaphragm, (I was careful removing cover but still must have broke some tabs). Car ran much better after replacing the whole valve cover. Good luck
Old Apr 12, 2018 | 02:07 PM
Scooter24's Avatar
Scooter24
Hmmmm. Did u by chance take pics of how the tabs mounted? I'm thinking I might attempt to replace the diagram if it's bad. My question is if I take that little cover off can I leave it off and still drive it until the new diaphragm comes in or should I order it then attempt to take it off?
Old Apr 12, 2018 | 03:56 PM
S-2013's Avatar
S-2013
I drove mine with a torn diaphragm but I wouldn’t do it again. Internal engine pressure was so high with engine running, I couldn’t even remove the oil cap. Imagine what that pressure will do to your seals over time. Plus the car ran like crap at idle. Most if not all these aftermarket diaphragms come from Russia so shipping takes quite awhile. I waited almost a month only to lose it in less than a week.
Old Apr 12, 2018 | 04:02 PM
Scooter24's Avatar
Scooter24
https://www.youtube.com/watch?v=LG_8...&feature=share
I actually just watched this video after my last comment. My car runs just fine no issues as of right this second. Well I have a issue from when I replaced the fuel fiter but that's besides the point ha. I'm going to order one and give it a shot. If it works I save $300 pus for a little while if it doesn't then oh well, I'm buying a new valve cover.
Old Apr 13, 2018 | 04:04 PM
jcwcoopster's Avatar
jcwcoopster
Buy a new valve cover and call it a day.
Old Apr 13, 2018 | 05:22 PM
Scooter24's Avatar
Scooter24
I'll take my chances fist. Big price difference.
Old Jun 19, 2018 | 02:08 PM
Scooter24's Avatar
Scooter24
I ended up replacing the diaphragm and it seems to have fixed the issue. The "hisssing" sound went away so all seems good. Only thing is today I was under the hood doing general stuff and I noticed a little oil residue around what looks like an opening in the plastic where the diaphragm is. I don't recall if I've ever saw oil here when it was "stock". There still isn't a noise just a little residue. My question is, is this normal and how does this diaphragm actually work? Does it vent to atmosphere when crankcase pressure is too high? If that's the case oil residue should be normal?
Billiho
Jun 3, 2019 05:44 AM
Gabe3
Feb 25, 2019 01:24 PM
greatfrog
Jul 16, 2017 03:25 PM
minnella
Feb 4, 2016 02:56 PM
toddcann
Mar 22, 2014 10:33 AM
