valve cover PCV valve
Old Jan 27, 2016 | 12:21 PM
minnella's Avatar
minnella
so I am told and am reading the entire valve cover has to be replaced because the PCV valve is not removable...this is absurd...$350 + in lieu of $10 for a PCV.
Anyone figured out a work around on this one?
Old Jan 27, 2016 | 12:28 PM
DaGriz's Avatar
DaGriz
Mine is removable on 2008 R52. On line for about $30
Old Jan 27, 2016 | 12:36 PM
nkfry's Avatar
nkfry
If you have a second generation car there is no way around it you need to replace the valve cover to fix the PCV.
MINI Valve Cover N14
We have them instock and ready to ship.
I have yet to see an N12/16/18 need a valve cover but the N14 is such a problem we have at least 4-5 on the shelf at any given point.
The gen one cars use a cheap thread in PCV valve.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 27, 2016 | 01:38 PM
AoxoMoxoA's Avatar
AoxoMoxoA
If it helps, look at it as a "high end" $350 PCV valve which comes with a free valve cover...
Old Jan 27, 2016 | 07:48 PM
DaGriz's Avatar
DaGriz
I'd be looking at some JBWELD and valve from a Chevy.
Old Jan 29, 2016 | 12:55 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Due to the redesign of the valve cover on the R56, it is not uncommon for the valve cover to leak from the PCV valve. Unfortunately it is no longer possible to just replace the PCV valve--an entire new cover must be purchased. MINI has updated the valve cover HERE. It comes with the gaskets, oil cap and mounting hardware.
888.280.7799 | 6am - 5pm PST
Old Feb 4, 2016 | 05:29 AM
You have to get the whole cover and the new cover for the N14 engine does not come with all the stickers and badges, but does come with the main gasket set.
Here is all the info:
We have them here and all the sticker and emblems as the new vales covers don't include them. 11127646555
http://www.ecstuning.com/Search/11127646555/ES2601877/
OEM MINI part number: 11127572851 : Click the picture below for item.
http://www.ecstuning.com/Search/11127572851/
MINI Valve cover Emblem Part # 11127594876
http://www.ecstuning.com/Search/SiteSearch/11127594876/ES514833/
Oil Label sticker Part # 01000419179 ( Which is used on all MINI engine bays in multiple locations dependent on year and model )
http://www.ecstuning.com/Search/SiteSearch/01000419179/
And the little yellow ignition coil sticker looks to be part #71227618790
http://www.ecstuning.com/Search/SiteSearch/71227618790/ES2674957/
And what it look like:
Old Feb 4, 2016 | 02:36 PM
minnella's Avatar
minnella
I am sorry but it is not reasonable to engineer these parts this way. Throwing a valve cover in the dump to replace a $5 part is not how this should work. Same issue with the thermostat housing. This should be a class action suit like the timing chain tensioner.
Old Feb 4, 2016 | 02:56 PM
J Free's Avatar
J Free
It's horrible engineering. It would be one thing if these were forever parts, but as a maintenance item, come on.
PelicanParts.com
Feb 10, 2016 10:52 AM
minibdb
Feb 3, 2016 01:51 PM
Alpha Motoring
Jan 27, 2016 10:50 AM
PelicanParts.com
Jan 25, 2016 03:19 PM
U.S.A. Ranger
Jan 25, 2016 01:36 PM
