How do you compress the brake piston???
Old Mar 31, 2018 | 10:20 AM
Cngizbleevng's Avatar
Cngizbleevng
I've changed out a number of brake pads over the last 10 years, but this Mini Cooper is something else.
I'm replacing the rotors and brake pads and I'm using a clamp to try to compress the piston to allow for more space for the pads. I've taken the cap off the brake fluid reservoir and siphoned off excess fluid.
I can't get the damn piston to retract into the housing. Applying about all the force I can with the C-clamp and it's not budging.
Anything I'm missing?
Old Mar 31, 2018 | 10:46 AM
Cngizbleevng
Well, I just consulted the Haynes manual and it mentions a 'special tool' that allows the piston to be rotated clockwise while compressing it. What a load of crap!
Old Mar 31, 2018 | 10:59 AM
gjxj's Avatar
gjxj
screw in rears are pretty common most cars with rear disks since the 80's. Its due to the parking brake mechanism. The alternative is to have a drum brake inside the hub, which you mostly see on trucks/suv's.
Old Mar 31, 2018 | 11:39 AM
Uber Commuter's Avatar
Uber Commuter
^Yep; the piston is a screw in type. you can rent the tool you need at most any of the chain auto parts stores. If you look at the face of the piston, you'll see two indents, those are what you "sit" the caliper tool in to twist and compress it.
If you don't have any nearby, you can twist it carefully with a set of pliers while you compress it with the clamp. If you choose to do this, just be really careful not to damage the piston; and try at your own risk...
Old Mar 31, 2018 | 11:45 AM
Cngizbleevng
Well, this is what I just did. Trying to compress the piston while rotating it wasn't easy, but I eventually got it. Now for the other side.
Old Mar 31, 2018 | 11:54 AM
GPMini's Avatar
GPMini
Time to upgrade your tool box
https://www.ecstuning.com/b-schwaben...ces/pbk-11pcs/
Old Mar 31, 2018 | 12:17 PM
Uber Commuter
Old Mar 31, 2018 | 05:18 PM
Cngizbleevng
Well, I was able to complete the job with a pair of slip-jaw plier and the C-clamp. Once I got a feel for it, it wasn't too bad.
Now to clear that pesky brake light on the dash.
Old Mar 31, 2018 | 10:59 PM
GPMini's Avatar
GPMini
OOPS! My bad, excuse me for trying to support an actual MINI vendor.
Old Apr 1, 2018 | 04:22 PM
Uber Commuter
I buy many products from ECS Tuning for 3 of my 4 cars (Mini, VW, BMW). But I don't pay them double the actual price of a product when there is no reason for it...
If you prefer to do that "because they are a MINI vendor" then feel free, it's your money.
Old Apr 1, 2018 | 04:43 PM
DneprDave's Avatar
DneprDave
I bought one of these for my brake job.
https://www.harborfreight.com/disc-b...-pc-63264.html
Old Apr 2, 2018 | 09:11 PM
dmyer's Avatar
dmyer
That kit covers just about any caliper you will encounter... I have used mine often on many different cars I own.
sunolmike
Apr 18, 2020 04:47 PM
Z06C5R
Apr 9, 2013 03:41 PM
RT4
Mar 23, 2013 01:51 PM
YMINI
Suspension
Feb 7, 2011 10:16 AM
sprp85
Tires, Wheels, & Brakes
Sep 20, 2008 09:43 AM
