I can't compress the Rear Brake Piston (With the Proper Tools!)
It is kind of urgent ..
I have the HF compress kit but!
The piston is not moving at all.
Everything is attached to the tool right and man, it is just STUCK
Parking Brake off, Brake pedal fresh, Reservior open, etc...
I even took off the parking break springs from the caliper assembly..
Ugh
Anyone have any ideas wtf is wrong?? its getting H O T outside and i'm stuck on the FIRST corner......
Any help would be appreciated!
Thanks in advance!
Ugh
Thanks in advance!
i use the HF tool at the track to change pads. sometimes it is simple.....hook it up and turn the handle....other times i have to apply pressure, back it off, reapply, repeat as necessary. i've just learned to not get frustrated when it doesn't go perfectly the first time. it still only takes a few minutes to do. i do understand your concern when it doesn't work like it's supposed to work. i don't know why. i just know that if i back off, then go again, it eventually works.
iamcamkeenan
08-10-2015 03:31 PM
