Oil usage
Old Mar 18, 2018 | 02:19 PM
CoryT04's Avatar
CoryT04
Oil usage
I have an 07 mcs I tend to go through oil kinda fast I know I have a very small oil leak from the pan but nothing to worry about just now sure where it’s going to
Old Mar 18, 2018 | 02:56 PM
DneprDave's Avatar
DneprDave
Probably, mostly dripping on the ground, fix that leak.
Old Mar 18, 2018 | 03:53 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
How many miles?
You could be losing oil through the PCV system and it's getting burned up in the engine. That will clog up the engine with carbon crud and also destroy your catalytic converter.
Has the valve cover ever been replaced? The pcv system is integrated into the valve cover, the only way to fix it is to replace the whole cover. There is an updated version out that does a significantly improved version of separating oil out of the crank case vapor. Suggest you check for a lot of oil in the pcv vent lines coming out of the valve cover - one that goes to the turbo inlet at the front driver's side, and one coming out the back passenger side that goes to the throttle body. Also check if there is a lot of oil built up in the throttle body. Replacing the valve cover is an easy DIY.
Old Mar 18, 2018 | 04:10 PM
CoryT04's Avatar
CoryT04
Originally Posted by squawSkiBum
How many miles?
80k miles and I don’t think it has been replaced at all I bought it at my work
Old Mar 18, 2018 | 04:11 PM
CoryT04's Avatar
CoryT04
There isn’t a catalytic converter I bought Mario karts down pipe
TJANK
Oct 31, 2013 08:37 PM
Goliath79
Jun 2, 2012 07:40 PM
BriguyR56
Mar 18, 2012 07:13 AM
MINI Marvin
Feb 21, 2012 06:48 PM
bardot861
Feb 4, 2012 02:54 PM
