N14/N18 High Pressure Fuel Pump teardown and refresh
Old Oct 29, 2019 | 12:07 PM
  #151
geofox784's Avatar
geofox784
Originally Posted by Jakomcbean
I know this thread is a bit old but it looks like NewTIS had the testing procedure and a description of what goes south on these pumps. Seems like temperature was a factor on those pumps CJ was shuffling around. They probably had differing amounts of oil left internally. I would imagine that this is some type of Vacuum pump oil. My wife has a freeze drying machine that uses a huge vacuum pump of similar design. The HPFP oil looks feels and smells just like it. I guess it depends how the pumps leak as I wonder if they truly cannot be refilled.
https://www.newtis.info/tisv2/a/en/r...nit/1VnXqS8AjN
woah... This is a huge update
Old Nov 3, 2019 | 01:55 PM
  #152
gumpo's Avatar
gumpo
Hey all,
I used to own an N14 with HPFP issues but now unfortunately own a Porsche Panamera with the same issues and remembered reading this thread. The Panamera HPFP's are very similar and made by Continental also. Mine hasn't completely failed but is showing symptoms of it failing imminently and unfortunately, like any Porsche parts, it seems that I'm going to be shelling out around £1200 which got me wondering about trying to fix mine. Is anybody closer to knowing what oil goes in these and whereabouts? I have some spare AC compressor oil knocking around and wondered if that was similar stuff? I'm thinking of maybe having a play around tomorrow but any advice is greatly appreciated!
Cheers
Old Nov 7, 2019 | 08:05 AM
  #153
texasmontego's Avatar
texasmontego
I just read this thread as well and it’s extremely informative. However, I haven’t seen any alternate solutions to pump replacement. Unless someone has another route, it appears prices for the pumps has gone back up $700+. Surprising prices haven’t gone down with so many that fail over time (economies of scale).
Old Nov 7, 2019 | 11:15 AM
  #154
Jakomcbean's Avatar
Jakomcbean
There is a guy on Facebook who claims to rebuild these pumps. I don’t know what he has figured out. Maybe we could play stupid and ask what he does. Search for High pressure pump Mini Cooper rebuilt.
Facebook Post
Old Dec 9, 2019 | 09:04 AM
  #155
Torquehead's Avatar
Torquehead
Thanks Jakomcbean!!!
This would appear to confirm that leakage of oil is the culprit and it even provides for a special tool to confirm that oil leakage has happened. Although the tool is not cheap at around $70 to $90. Now all we need to do is to figure out how the oil is leaking and how to refill the pump. Personally I would not be too worried about the exact spec of oil. This pump looks similar to a hydraulic piston pump so any good quality hydraulic oil should work. Also if the pump is torn apart, surely it can be refilled during assembly. The factory had to do it, so why not us in our workshops?
If I understand correctly, at least one member has reported that the pumps are leaking externally and this should provide our best clue as to the source of leakage.
Last edited by Torquehead; Dec 9, 2019 at 11:58 AM. Reason: fixed error in type of pump. Changed vane to piston
Old Dec 9, 2019 | 09:26 AM
  #156
Torquehead's Avatar
Torquehead
Leakage path?
Looks like most likely oil leakage path is past item 11 (the drive flange). This is probably the best way to completely refill the chamber, by adding oil through the drive flange opening during re-assembly.
Old Dec 11, 2019 | 06:24 AM
  #157
Torquehead's Avatar
Torquehead
So having gone back and re-read this thread, it now seems obvious that the loss of oil is via the thermal compensator. I am going to buy a new pump and then attempt to refill the oil and repair (if possible) the leak on the old pump. I will also try to source the thermal compensator separately if I can find a part number on it and will post results here.
Old Dec 11, 2019 | 07:51 AM
  #158
Jakomcbean's Avatar
Jakomcbean
So as it seems this guy in Canada on Facebook has figured out exactly what goes wrong since he repairs them and has customers giving him feedback. He even claims to have repaired an eBay pump. Seems like we are near to a definite diagnosis. He is very stingy on the details of what he actually does. He is also apparently fairly rude to converse with. Sounds like he is keeping things close to his chest. Can’t say I blame him. This make me think the solution is easier than most think.
Old Dec 11, 2019 | 08:52 AM
  #159
Torquehead's Avatar
Torquehead
I agree, the solution is easier than we think and it is almost at hand. I am guessing Facebook guy has found a source for thermal compensators. They are likely quite cheap as it is just a couple of pressed tin cups that are crimped together with a spring loaded diaphragm or piston inside. Does anyone have a good photo of the numbers stamped on the compensator?
Old Dec 12, 2019 | 06:54 AM
  #160
SunBird's Avatar
SunBird
Will be checking mine out. Has been exhibiting the stumble symptoms,
Old Dec 12, 2019 | 07:04 AM
  #161
Torquehead's Avatar
Torquehead
Ok here is an update on my High Pressure Fuel Pump (HPFP).
Background Info:
2010 Mini Cooper S (N14 engine)
102,000 kms
All the usual symptoms of a failing HPFP like:
Hard cold start
Rough idling
Stalling
Misfire/backfire
Goes into Limp Mode with half-engine check light
Error codes for misfire and low fuel rail pressure
When fully warmed up, sometimes it runs ok
Did walnut blast of intake valves and installed new spark plugs and ignition coils but still no joy.
So last night, I removed the HPFP and performed the measurement on the HPFP thermal compensator as indicated by this TIS https://www.newtis.info/tisv2/a/en/r...nit/1VnXqS8AjN
The TIS states that any value less than 26mm is good. Well mine measured 24mm so in theory it is good. It was measured with a cold engine but in a warm garage. So currently the HPFP has been placed outdoors in -6C temperature. After about 6 hours, I will re-check the measurements. The TIS method is like a dipstick for checking the oil level inside the HPFP. I could not detect any visible signs of external oil leakage on my pump and the "dipstick" indicates the oil level is fine so my pump appears not to suffer from lack of oil but that does not rule out a pump failure since there are many other ways a pump can fail.
Old Dec 12, 2019 | 07:40 AM
  #162
Jakomcbean's Avatar
Jakomcbean
I have a old dead pump and a new slightly used one that are both out of my car. I’ll check the measurements on both and see what the difference is.
Old Dec 12, 2019 | 08:01 AM
  #163
Torquehead's Avatar
Torquehead
That would be great to compare measurements. Since the TIS measurement tool measures from the bottom of the indented surface, I also used the same surface but because my vernier caliper would not fit down into the indent, I first had to measure the depth of the indent which I found was 3 mm, and then I measured from the top of the indent down to the diaphragm and subtracted the 3mm from that measurement. Just so we are on the same page as far as measurement is concerned.
Old Dec 12, 2019 | 09:24 AM
  #164
Torquehead's Avatar
Torquehead
The cold weather (-6C) test of my thermal compensator yielded the same measurement of 24mm so the temperature difference of about 16 degrees Celsius did not affect the measurement.
Old Dec 12, 2019 | 02:33 PM
  #165
Hopefully they will hold up rebuilt, we have not seen anything hold up with the Oasis brand ones https://www.northamericanmotoring.co...ebay-hpfp.html
If we can find a source some of the internals/seals we will post up.
Old Dec 12, 2019 | 05:29 PM
  #166
Jakomcbean's Avatar
Jakomcbean
All the rebuilds that I have known fail shortly after. Heard the post where this guy claims to have success with a Chinese pump.
Old Dec 12, 2019 | 07:13 PM
  #167
Mark Karas's Avatar
Mark Karas
I've been researching this topic for the past several months, a seller on eBay sent me a link to a guy in Brazil who explains the failure behind these pumps. If you have a chance do you mind dropping the link for the TIS measurement tool? I have not had any luck finding it with the part number given!
Thank!
Old Dec 12, 2019 | 07:49 PM
  #168
Jakomcbean's Avatar
Jakomcbean
Sure the link has been posted here a few times. It’s at
https://www.newtis.info/tisv2/a/en/r...nit/1VnXqS8AjN.
I would love to see that link where the failure is explained would you be able to share that with us?
Old Dec 13, 2019 | 06:55 AM
  #169
Torquehead's Avatar
Torquehead
The TIS measurement tool can be purchased here. It allows for checking the pump without removing it. I have no affiliation with the vendor.
https://www.ecstuning.com/b-genuine-...e/83302344569/
Last edited by Torquehead; Dec 13, 2019 at 08:28 AM. Reason: to correct wrong part number for tool
Old Dec 13, 2019 | 07:04 AM
  #170
Torquehead's Avatar
Torquehead
Mark, you can probably build one of these tools out of some brake line and throttle cable. I tried to build one out of a manual shutter release for an old 35mm camera. It seemed like a good idea at the time but it was a total fail and I spent more time on the tool than it took to remove the pump and measure it on my workbench. It took me about an hour to get the pump out and that's with me having never worked on a Mini engine before so I was working slowly and carefully.
Mark, I would also be very interested in the link to the guy in Brazil who has the pump issue all figured out. Can you please post here?
Old Dec 13, 2019 | 07:17 AM
  #171
https://www.northamericanmotoring.co...2&goto=newpost
Thought that was the service mode tool?
That special hook tool line is here: https://www.ecstuning.com/b-genuine-...e/83302344569/
Old Dec 13, 2019 | 07:53 AM
  #172
Torquehead's Avatar
Torquehead
Ooops. My bad on the tool part number. Is there any chance ECSTuning can update their webpage with a photo of the tool to avoid any future confusion. The TIS is rather misleading when it comes to the part number to be used for ordering the tool. A picture is worth a thousand words.
Old Dec 13, 2019 | 08:10 AM
  #173
No problem, we will update the part.
Old Dec 15, 2019 | 08:12 AM
  #174
Norbert Toth's Avatar
Norbert Toth
Very useful post! Thanks!
few months ago I bought new hpfp for my mini R56 and change it, but didn’t work. Then I took old valve into new hpfp but nothing. Start and immediatelly stop. Then I run with old pump and daily stoped engine at red traffic lights. Few days ago I want buy new pump at dealer but stop. I think I didn’t try old pump with new valve. I was looking for post about mini or peugeot hpfp same or not and looking for info about valve. Now I find your post what very logical and I put new valve into old pump. Earlier I measured pressure 3-6 kpa but now is show 4,8-11 kpa. How nice! Idle is not smooth but not stop and lowest pressure 4,7 kpa.
i will renew my old valve with new rings and take safe place for next time.
I’m very happy to find your post and very exiting how it will run tomorow!
thanks!
Old Dec 17, 2019 | 02:31 PM
  #175
Torquehead's Avatar
Torquehead
So my new HPFP arrived today and I installed it and the car started right up and idled perfectly. No misfires. Of course time will tell if this really cured the problems but the interesting thing for me was comparing the measurements of the old and new pumps. As you recall, the TIS said anything less than 26 mm was fine. Well, I am not sure we can rely on that as a hard and fast rule. My old pump measured 24mm but the new pump measured 19 mm. That's a huge difference. So for me, at 24 mm the car would still run but mostly in limp mode. It would appear that anything greater than 19mm indicates some loss of oil and by the time you reach 24 mm, it is time for a new pump.
Hey Jakomcbean, did you ever get around to measuring all of your old pumps? Would love to hear what you found.
