Supercharger PTO Worn Gears
Old Sep 23, 2019 | 06:33 PM
  #26
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Originally Posted by CarFreak427
Nope, it did not. The new seal seems to be an all around higher quality piece.
Thanks for confirming. That is consistent with fullmoonguru's observation. That is why so many PTO gears died of premature death. BMW and Eaton really screwed this one up.
Your new seal has.
Old Sep 24, 2019 | 08:58 AM
  #27
fullmoonguru's Avatar
fullmoonguru
CarFreak427, glad this helped you. Not sure how many miles since I did mine but it's my daily and it's been 2-1/2 years so I'm calling it done.
Yeah the original seal is not of the typical design for oil seals. I keep thinking their must be some reason they went with that particular design but really can't think of what that would be.
Please share the new seal part number and where to find it!
Old Sep 30, 2019 | 02:36 PM
  #28
CarFreak427's Avatar
CarFreak427
I would share the link but it appears I may have gotten the last of them. The Amazon listing says out of stock with no time frame. I still have two though, since it came in a pack of 3. Should anyone need one, I’ll keep them around.
Old Sep 30, 2019 | 03:08 PM
  #29
fullmoonguru
Oh I thought you were saying you found an alternate part number to replace the one they aren't manufacturing anymore.
Old Oct 1, 2019 | 06:22 AM
  #30
fullmoonguru
The measurements for this seal:
OIL SEAL 15.88MM ID 28.55MM OD 6.35MM WIDTH
Old Oct 2, 2019 | 11:27 AM
  #31
pnwR53S's Avatar
pnwR53S
With all indications this seal from National 471466v is a cross compatible. The slight dimensional difference is likely due to metric-imperial-metric-imperial... rounding error to the power of 10. It is spring loaded lip.
Actually if you look at the shaft size and housing bore, it is exact in mm.
Old Oct 3, 2019 | 10:37 AM
  #32
pnwR53S's Avatar
pnwR53S
pto gear shaft seal
I picked my seal up at O'Reilly's. It is tiny. Under $8. fullmoonguru is the man that blazed the trail. It is made in Mexico, thanks to NAFTA.
Stella11
Apr 14, 2019 05:33 AM
GoThingNC
Nov 26, 2016 07:16 PM
lathedog
Jan 5, 2015 11:32 AM
JAB 67
38
Nov 18, 2009 02:37 PM
herbie hind
Sep 16, 2007 08:52 AM
