Sunroof drain confusion
Old Apr 17, 2016 | 09:21 AM
bavmotors's Avatar
bavmotors
My car has been leaking down the door on the inside from somewhere so I followed the drain tube thread and realized its in fact the drain tube. It seems disconnected however I can't seem to figure out where the other end is. Here's what I found but I can't figure out where the other tube end is.
Attached Thumbnails Sunroof drain confusion-image-3539434700.jpg   Sunroof drain confusion-image-3447346957.jpg
Old Apr 17, 2016 | 02:47 PM
Da_Ghost's Avatar
Da_Ghost
Is it the front or the rear drain?
The front ones are fairly easy to see as they are really short:
As for the rear, they exit at the hatch. When the hatch is open, you can see the two rubber grommets near the hinges. Here's a post with good pictures.
https://www.northamericanmotoring.co...ater-leak.html
Old Apr 17, 2016 | 02:58 PM
bavmotors's Avatar
bavmotors
Originally Posted by Da_Ghost
Is it the front or the rear drain? The front ones are fairly easy to see as they are really short: As for the rear, they exit at the hatch. When the hatch is open, you can see the two rubber grommets near the hinges. Here's a post with good pictures. https://www.northamericanmotoring.co...ater-leak.html
front, so it should have a small connection to the insulated white tube?
Old Apr 17, 2016 | 03:06 PM
Da_Ghost's Avatar
Da_Ghost
It's actually the metal tube you see right below it on this picture, this is how I found the rubber tube when I lowered the headliner. The tube is off and sitting against the drain metal tube. That white insulated thing is the airbag.
And this was the result of the leak: http://imgur.com/a/tlmeQ
Old Apr 17, 2016 | 03:23 PM
bavmotors's Avatar
bavmotors
Ok, trying to do it without taking the headliner out too far. My leak is very similar except on the drivers side.
Old Apr 18, 2016 | 08:26 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Not sure what thread you saw, but HERE is another with close up shots of the front drain tube. Can't really tell from your images, but in that thread the individual added hose clamps to keep it from coming off.
888.280.7799 | 6am - 5pm PST
Old Apr 18, 2016 | 09:13 AM
bavmotors's Avatar
bavmotors
thanks I'm gonna finish this task today. Funny the member who made that thread is local to me.
Old Apr 18, 2016 | 09:23 AM
PelicanParts.com
Vendor
hah such a small world. No problemo! Let us know how it goes.
Old Apr 30, 2016 | 04:24 PM
bavmotors's Avatar
bavmotors
What a pain to reattach the hose, had to lube it up a little to fit it on.
Old Apr 30, 2016 | 05:10 PM
ZippyNH's Avatar
ZippyNH
Hey...when lube is involved, the fun almost always follows!!
Aug 30, 2017 05:08 AM
Michael Nicely
Aug 1, 2016 10:31 AM
Greggz
17
Apr 26, 2016 12:51 PM
blue al
Apr 17, 2016 05:38 AM
Chuck W.
Apr 14, 2016 02:40 PM
