Throttle body replacement cost
Old Apr 13, 2016 | 05:38 PM
ingrdo's Avatar
ingrdo
I drove Tater (as in 'let 'er rip, Tater Chip!), an '06 S convertible, from Helena to the Murray, UT Mini dealership for the passenger air bag recall and asked them to investigate the limp mode issue. I'd researched here enough to know that it was probably either the throttle body or engine wiring harness. So their diagnosis of throttle faults at potentiometer 1 & 2 seemed spot on and they've suggested the whole thing be replaced.
What didn't seem right was that they quoted $94 to replace a brake light & $40 to replace a windshield wiper!! So, I'm wondering if their $494 to replace the throttle body is anywhere near accurate?
Does anyone have any words of wisdom?
Thanks! ingrid
Old Apr 13, 2016 | 06:02 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Seems like an indy shop could do it for a lot less.
Old Apr 13, 2016 | 06:16 PM
ingrdo's Avatar
ingrdo
I called a guy in Helena that others w/ Minis have recommended & trust. He said that the dealership had to do it because of programming issues that they weren't equipped for? I researched the parts prices and it doesn't seem too over the top if their quote includes labor. I'll be asking them that tomorrow b/c while fixing the airbag issue, they buggered the radio. Joy.
Old Apr 14, 2016 | 08:08 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Dealers will always cost more. When I worked at the dealer we quoted $45 to replace the cabin air filter. That's for parts and labor. As you can see, the throttle body part is HERE. Did they tell you how much labor is part of the quote they gave you? HERE is a DIY on how to replace it. You'll want to call a MINI/BMW shop that specializes in them specifically as they will be the ones with the proper equipment to do specific repairs. I see you're in Colorado. Do you live near Copper Mountain? It's a bit of a trek, but AutoHaus of Boulder works on MINI's and you can give them a shout. Really great shop.
888.280.7799 | 6am - 5pm PST
Old Apr 18, 2016 | 04:59 PM
jamez's Avatar
jamez
Unfortunately the dealer claimed that the TB replacement job required coding to me as well... Only after they had the car in their possession (I didn't have time to do what is really a 1h job myself). I pressed them for answers on what needed to be coded, and after further digging.... They were "mistaken" about the coding. All in all, after all the hassle, I could (and have since) done the job in 30-45mins. A $130/h rate is not unreasonable for a dealer, plus the part cost.... But that does seem a bit high for the quote (perhaps more was being "done"?)
Old Apr 19, 2016 | 08:14 AM
Brochacho's Avatar
Brochacho
I'm curious as to what coding needs to be done. I haven't heard anything about it needing coding, and I recently replaced my throttle body trying to fix an issue with intermittent starting troubles.
Dave
Old Apr 19, 2016 | 09:40 AM
jamez's Avatar
jamez
There isn't any coding that needs to be done... it was the "line" that the dealer "fed" in order to "scare" me into needing the job to be done by them.
I had the part, but they claimed it needed to be coded... I didn't have the time or knowledge back then to argue.
Old Apr 27, 2016 | 07:56 AM
PelicanParts.com
Vendor
The Bentley Manual states after the install of the new one to reset the DME control unit adaptation values using diagnostic scan tool. That's all, no coding.
Old Apr 27, 2016 | 03:03 PM
Brochacho's Avatar
Brochacho
I will have to look for that in INPA...Thanks!
quickcoop
Dec 4, 2020 09:05 AM
JOHN21BLACK
Mar 24, 2016 03:45 PM
MiniDad08
Mar 23, 2016 01:59 PM
kryall
Mar 21, 2016 08:51 AM
JWA
Mar 20, 2016 04:29 PM
