Bulb indicator
Old Nov 4, 2015 | 08:44 AM
uconnhuskiesfans's Avatar
uconnhuskiesfans
Bulb indicator
Within the tach, I am getting a bulb out indicator. I have gone through every exterior bulb on the car and they are all working fine (including the license plate bulbs). Not sure of next steps. Wondering if the hidden menu could assist me in figuring out what bulb the car thinks is out. I am wide open to ideas or suggestions in tracking down the issue so i dont have to keep ignoring the bulb out indicator
Old Nov 4, 2015 | 08:57 AM
nkfry's Avatar
nkfry
Are you running LEDs? That's the problem.
Have you had someone press the brake pedal and confirm both bulbs in either socket function?
Reverse bulb?
Rear fog lights, front fog lights?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 4, 2015 | 10:01 AM
uconnhuskiesfans
not using LEDs. Yes, had someone in the car testing all bulbs including fogs front and read, brake pedal etc.
Old Nov 4, 2015 | 10:06 AM
Slave to Felines's Avatar
Slave to Felines
We've also seen cases where contact between the bulb and socket was good enough for the light to light up, but bad enough that the warning system detected a problem. Make sure the connections are clean and tight.
Old Nov 4, 2015 | 10:38 AM
uconnhuskiesfans
so go from bulb to bulb? or is there a way within maybe the hidden menu to find which bulbs it feels there is an issue with. if there is a way, can you offer any insight into where in the hidden menu or other to find it
Old Nov 4, 2015 | 10:54 AM
nkfry's Avatar
nkfry
You'll need to manually inspect each socket unless you have a dealer level scan tool that will tell you exactly which socket is showing a deviance.
Phone:586-792-6464
Old Nov 4, 2015 | 11:12 AM
uconnhuskiesfans
in this thread https://www.northamericanmotoring.co...ml#post4141032
the person said they accessed the hidden menu and within found this
CC ID 122 (indicator, front left, failure)
CC ID 125 (indicator, rear right, failure)
CC ID 133 (rear light, left, failure)
maybe there is a way to do something similar without going bulb by bulb? I am not sure where in the hidden menu he found this though. Ive asked, no reply, yet.
Old Nov 4, 2015 | 12:01 PM
TrueEddie's Avatar
TrueEddie
This happened to me before. But the warning message specifically stated left fog light, so it was easy to find and fix.
Old Feb 24, 2016 | 01:07 PM
BlackIce's Avatar
BlackIce
This warning light came on recntly in my 2012 Mini justa and I found a license plate light burned out. Today I replaced that bulb with a new one from the Mini dealer, but the warning light still comes on each time I start the car.
QUESTION:
Should the warning light reset itself with time or do I have to do something to reset it?
THX!
Old Mar 24, 2016 | 07:19 AM
uconnhuskiesfans
can anyone direct me how to access this hidden menu? More specifically, where within the menu to find bulb information. I am stilling having the bulb warning light come on with no bulbs out and my daughter is taking a road test with the Mini. Unsure if they will not pass her because of this
Old Mar 24, 2016 | 08:23 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Can't link the thread, but here is some info below that might help.
There is something similar for the 2nd Gen...trying to locate that info now. From memory I think it was to hold the ODO reset button for 12 seconds or some such thing. Add up your VIN digits, enter that at some point and then you get access to the menu.
(read the YouTube comments for additional info)
888.280.7799 | 6am - 5pm PST
tacticalbacon02
Nov 13, 2015 06:08 AM
polibureau
Suspension
Nov 6, 2015 02:35 PM
silence2-38554
Nov 6, 2015 11:36 AM
Tires, Wheels & Brakes
Oct 28, 2015 10:49 AM
DaGriz
Oct 21, 2015 05:36 AM
