Oil Filter Housing Cap Needed
Old 09-21-2015, 01:52 AM
IDOXLR8's Avatar
IDOXLR8
IDOXLR8 is offline
Any one out there have a oil filter housing cap for a base 03 Cooper? I'm looking for the original style with the plastic center support, thanks AL.
Old 09-21-2015, 11:06 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is offline
Vendor
Any reason why you're needing that style? The oil filter support is no longer needed as the current version oil filter has a built-in support. 11427563763 here.
888.280.7799 | 6am - 5pm PST
Old 09-21-2015, 12:31 PM
IDOXLR8's Avatar
IDOXLR8
IDOXLR8 is offline
Part of the plastic filter support is broke off on mine, got damaged when a filter with the inner support was install to the old style cap.
Old 09-21-2015, 01:50 PM
ECSTuning is offline
Received 1,967 Likes on 1,767 Posts
Good luck , If you cant find the older version. Otherwise you will have to change over.
Otherwise :
https://www.northamericanmotoring.co...ilter-wtf.html
Old 09-21-2015, 08:11 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
You will have to either get the entire housing with the new style that no longer has the plastic insert. Or have to find a used one, but most of them were broken or thrown away over the years.
Sorry but NO you can not just put the new style cap on your old housing as it won't push the filter down far enough and the oil pressure light will stay on.
We have the new housings avail if you need a new one.
http://www.waymotorworks.com/oil-fil...52-cooper.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 09-22-2015, 05:52 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Rich.Wolfson is offline
I have a cap you can have but I am not sure it's the one you need. Artoo was build October 2003 so it's early in the build year. But there is no plastic inside the cap. It's all aluminum.
If it's the one you need, no problem as I bought it before I realized that getting it on was not a function of the cap but just technique.
///Rich
Old 09-23-2015, 01:00 AM
IDOXLR8's Avatar
IDOXLR8
IDOXLR8 is offline
Do I need to replace the complete oil filter housing to use your newer cap? One of the members said I needed to change out everything, please advise, thanks, AL.
Old 09-23-2015, 03:14 PM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
From Way in post #5 above:
"Sorry but NO you can not just put the new style cap on your old housing as it won't push the filter down far enough and the oil pressure light will stay on."
Old 09-24-2015, 05:05 AM
IDOXLR8's Avatar
IDOXLR8
IDOXLR8 is offline
Oil Filter Cap For Sale?
Okay, back to my question, any one selling a good condition oil cap far a base 2003 MINI?
07-16-2020 12:54 PM
mrjolliff
10-09-2015 05:55 AM
08-12-2015 01:24 PM
M7Speed
08-06-2015 01:48 PM
kwijmbo
08-05-2015 09:00 PM
Quick Reply: Oil Filter Housing Cap Needed
