blow off valve
Old Aug 1, 2004 | 09:17 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
blow off valve
is the minis blow off valve silenced and if so can you take the silencer off? wat would this do a friend of mine said it gives it a nice pitshh sound as you shift? true?
Old Aug 1, 2004 | 09:23 AM
JCampos's Avatar
JCampos
The mini uses a bypass valve, not a blowoff valve.
Old Aug 1, 2004 | 09:25 AM
littlehandegan
my bad.....but is this all still true
Old Aug 1, 2004 | 09:26 AM
JCampos's Avatar
JCampos
Have you ever heard a turbo'd car?? That sound.
Old Aug 1, 2004 | 09:27 AM
littlehandegan
yes i have heard that....
Old Aug 1, 2004 | 09:30 AM
Flatsix's Avatar
Flatsix
The Cooper S is supercharged, there is no blowoff valve. There's no way to make that quick burst of air sound with our car, sorry to dissapoint you.
Old Aug 1, 2004 | 09:37 AM
Bisch's Avatar
Bisch
Yes, you can do it. Check here:
http://www.sunamiturbo.com/sunamiturbo.html
If I ever see a MINI with this, I will beat the driver silly! No, seriously.
Old Aug 1, 2004 | 09:55 AM
JCampos's Avatar
JCampos
I agree... I would just out of my car and beat the ever living hell out of the driver.... I would feel pretty shitty if it really was turbo'd though so maybe I should set up a screening process
Old Aug 1, 2004 | 10:25 PM
kenchan's Avatar
kenchan
If you want just the sound, there is some 'simulated' turbo blow-off tone generator you can hook up. Check out some of those Honda tuner type magazines ads in the back. It does sound like a real blow off valve.... I
heard an Accord with one and it was pretty funny.:smile:
Old Aug 2, 2004 | 06:00 AM
USAMINICOOPER's Avatar
USAMINICOOPER
That Nice. But why not get the real thing. A twincharged Mini, 250 hp at the wheels. I drove it, amazing. And has blowout valve which will work for real.
https://www.northamericanmotoring.co...ht=twincharged
Old Aug 6, 2004 | 01:12 PM
Moorlockx's Avatar
Moorlockx
$150.00 for a fake turbo sound?? That's way past stupid!!
Old Aug 6, 2004 | 01:17 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Another difference between a turbocharged engine and the Roots-type supercharged MCS is the location of the throttle body. In a turbo (or a centrifugally supercharged engine), the compressor forces air through the throttle into the intake manifold. When the throttle is closed suddenly, a pressure wave can build up against the throttle and bounce back to the compressor causing at best an unpleasant sensation and at worst serious damage. In the MCS, the throttle is UPSTREAM of the supercharger, so it never sees compressed air. Slamming shut the throttle by lifting off the gas does nothing more than reduce the pressure on both sides of the supercharger. The bypass valve in the MCS goes one step further in allowing intake air to pass through the supercharger without significant compression.
So, the moral of the story is, a BOV is neither necessary nor a good idea for the MCS.
PsychoRallye
21
Feb 17, 2019 06:08 AM
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Nicefeet
Sep 24, 2015 06:53 PM
