Eaton M45 Supercharger Worn Shaft repair
Old Dec 26, 2014 | 07:36 PM
SlowLowR53's Avatar
SlowLowR53
Has anyone ever had to repair the end shaft on the charger where the pulley goes on? I previously had a V1 alta pulley on and the pulley damaged the shaft. It's worn pretty bad. I mounted a new V2 Alta pulley and all seemed well for a few days now it sounds like it's just spinning on the shaft. I don't get any boost. In fact I can't even hear the supercharger, just the noise of a spinning pulley. What can I do to fix the shaft ?
Old Dec 26, 2014 | 08:31 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We do a complete rebuild when we see this issue.
Old Dec 26, 2014 | 09:04 PM
SlowLowR53's Avatar
SlowLowR53
But everything is on the charger is fine.
Old Dec 27, 2014 | 03:10 AM
ZippyNH's Avatar
ZippyNH
Since removing and replacing a SC is about 5+hrs labor, and 100$ or so in gaskets, WHY fix a part that might be 90% worn out....remember, a SC is a wear item, it gets less efficient as it wears...
Then add in an week or more of downtime if you wait for your sc to be fixed, and two way express shipping....think it makes more sense to just do an rebuilt sc as an exchange, and start off fresh....remember, sometimes the most expensive way to fix something is by going cheap!! That's cause you pay to do it two times!!
Old Dec 27, 2014 | 05:55 AM
SlowLowR53's Avatar
SlowLowR53
Understood. Who does rebuilding at a decent price? ($500 and under)
Old Dec 27, 2014 | 07:16 AM
JAB 67's Avatar
JAB 67
Less than $500? No one to my knowledge.
Old Dec 27, 2014 | 07:19 AM
SlowLowR53's Avatar
SlowLowR53
Well i don't have much support and I'm still establishing myself being a student and all so I may just permanently weld the pulley to the shaft. Bring on the hate.
Old Dec 27, 2014 | 07:49 AM
IQRaceworks's Avatar
IQRaceworks
Shaft is steel...pulley is probably aluminum. Or is it steel? You could probably put a few small tacks on it as long as you don't get the shaft too hot and melt any of the oil seals.
You might be able to find a local bearing hose that carries those thin sleeves that are made to slide over worn shafts and repair them. I think you put epoxy on the shaft and slide it on.
Also..you could drill right thought the pulley and shaft and put a pin in it, that would probably hold really well also.
All of these are probably still just going to be temporary fixes....but it's worth a try.
Have you searched around on ebay, auto salvage yards, or other places to find a used supercharger?
Old Dec 27, 2014 | 09:56 AM
SlowLowR53's Avatar
SlowLowR53
I'm looking at those shaft sleeves now. Still searching around for a used charger under $500 think I may have found a shop that will rebuild for that amount. The shop is out of Florida
Old Dec 27, 2014 | 10:14 AM
Nicefeet's Avatar
Nicefeet
Nothing good has ever come out of Florida consider yourself warned
Old Dec 27, 2014 | 10:22 AM
Domiracer's Avatar
Domiracer
Could just replace the nose assembly on the SC with a used one!
Old Dec 27, 2014 | 12:04 PM
EuroTechsAZ's Avatar
EuroTechsAZ
Try a different brand pulley. The split collar type have issues that the tapered cone type ones do not have. Wouldn't hurt to throw a dap of green loctite 640 on there.
Old Dec 27, 2014 | 01:25 PM
WayMotorWorks
Vendor
you won't get a quality rebuild for that. you might find a used one if you look hard enough for that price, but not a rebuild.
Old Dec 27, 2014 | 05:07 PM
jhiggs26's Avatar
jhiggs26
This could work for your damaged snout shaft.
http://www.ebay.ca/itm/291332845816?...84.m1555.l2649
Jeremy
Old Dec 27, 2014 | 05:14 PM
SlowLowR53's Avatar
SlowLowR53
I've just bought and fitted the V2 Alta pulley which they claim will work on tapered shafts.. Guess mines is tapered beyond its tolerance
Old Dec 27, 2014 | 05:18 PM
SlowLowR53's Avatar
SlowLowR53
Jeremy
Thanks. I'm about to purchase that now. Exactly what I need!
Old Dec 28, 2014 | 12:41 PM
Debi's Coop S's Avatar
Debi's Coop S
Ebay has everything!!!!
Supertractor3
Apr 7, 2017 11:16 AM
sempaipaul
Sep 9, 2015 05:55 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Sep 3, 2015 03:01 PM
cw40342
Sep 2, 2015 06:01 AM
