Supercharger Specs???
Old Sep 1, 2015 | 07:06 PM
cw40342's Avatar
cw40342
I was wanting to know if anyone knows the torque specs or the eaton m45 supercharger? I am replacing the gasket on the top of it I am trying to figure what I should torque the bolts to.
Old Sep 1, 2015 | 08:36 PM
boostedhaze's Avatar
boostedhaze
Here are some general torque specs for supercharger related things. A clearer description of what spec you are looking for would help.
The large supercharger horn has 10mm bolts that should be torqued to 18 ft-lb.
There are 13mm bolts that attach the water pump to the supercharger, they should be at 18.4 ft-lb.
Similarly there are the 13mm bolts on the driver’s side of the supercharger, and the two on the passenger side that attach it to the block. These should be at 33.2 ft-lb.
Old Sep 2, 2015 | 06:01 AM
cw40342's Avatar
cw40342
Originally Posted by boostedhaze
Here are some general torque specs for supercharger related things. A clearer description of what spec you are looking for would help. The large supercharger horn has 10mm bolts that should be torqued to 18 ft-lb. There are 13mm bolts that attach the water pump to the supercharger, they should be at 18.4 ft-lb. Similarly there are the 13mm bolts on the driver’s side of the supercharger, and the two on the passenger side that attach it to the block. These should be at 33.2 ft-lb.
The larger supercharger horn the bolt that mount that horn to the actual supercharger.
NYMADMINI
Dec 14, 2016 02:33 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
gnhovis
Sep 28, 2015 10:56 AM
