oh oh...there's fluid at the bottom of transmission
Old Jun 28, 2004 | 05:08 PM
lmarie's Avatar
lmarie
I don't know what to think My husband, while changing my oil, found a small amount of clear-yellowish sticky fluid at the bottom of the transmission. He can't quite tell where it's coming from but told me it's not a bad leak but enough to collect and attract dirt. It never showed up on our garage floor. The problem is that my 02 is way past it's warranty. Please tell me this isn't serious
Old Jun 28, 2004 | 07:03 PM
pocketrocketowner's Avatar
pocketrocketowner
Your transmission actually has a seam along its diameter. This seam is basically metal to metal with a thin coating of sealant. Don't worry about it, just have Meesterr Hubby drag his lazy bones under the car say once a month and give it a good cleaning.........while he is at it he might give the bolts involved a tug with a wrench
Old Jun 28, 2004 | 08:42 PM
lmarie's Avatar
lmarie
Oh... I hope you're right. Meester mehanic hubby is now more worried than I am He thinks that I might've blown a drive shaft seal or something. He says that there's the same sticky stuff around the clutch area where the clutch cables? attach to the tranny. Is he parnoid or on to something?
Old Jun 29, 2004 | 05:15 AM
MSFITOY's Avatar
MSFITOY
I've found similar stuff too. What's up with this Does it say anywhere in Mini maintance about topping off the tranny?
Anyone else having this issue?
Old Jun 29, 2004 | 05:19 AM
Trippy's Avatar
Trippy
Is this really tranny fluid, or is it grease?
Could it be some assenbly grease and not a leak at all?
Tranny fluid is REALLY thin, like water, so if this is sticky and greasy, I'm thinking it might not be fluid leaking from the tranny.
Clean it off and watch. If it doesn;t come back, it was probably supposed to be there!
Old Jun 29, 2004 | 06:11 AM
MSFITOY's Avatar
MSFITOY
Mine would come back after a few hundred miles after wiping it off. And it IS sticky and yellowish/clear (like honey) as Lmarie described. Too thick to drip WTF is this stuff
Old Jun 29, 2004 | 04:29 PM
lmarie's Avatar
lmarie
m
Old Jun 30, 2004 | 07:12 PM
pocketrocketowner
I'm betting it is the sealant around your tranny split......relax...no worries....what are you doing looking under the darn thing anyways....
the other stuff around the cables surely is grease as the man said....
Old Jul 1, 2004 | 01:47 PM
hondacivic's Avatar
hondacivic
your fine. like pckrocket said, its sealant.. Its good to hear that people are changing thier own oil insted of paying people to do it. :smile:
Nick
Old Jul 1, 2004 | 03:14 PM
MSFITOY's Avatar
MSFITOY
LOL...I like to peek under her skirt once in a while.
I sure hope you guys are right as I sure wouldn't want to entertain takin Msfit in have them go "WTF did you do to this Mini?!?!"....ummmmm....everything
Thanks for the reassurance guys
Old Jul 1, 2004 | 07:06 PM
MSFITOY's Avatar
MSFITOY
interesting...my new sig doesn't doesn't show up on my past posts
Old Jul 9, 2004 | 10:22 AM
pocketrocketowner
I like your lights...are they good?
Old Jul 10, 2004 | 07:41 AM
MSFITOY's Avatar
MSFITOY
Mystery solved. The sticky stuff is apparently coming from my over saturated Alta intake filter. The filter oil was pooling benieth and draining onto my tranny
BTWl, the PIAA lamps are used for daylightrunning as they're kinda of small for anything but fog lamps at night.
Old Jul 13, 2004 | 02:34 AM
pocketrocketowner
Nifty lights anyways....:smile:
Old Jul 13, 2004 | 03:06 AM
SCoop's Avatar
SCoop
I just recently cleaned my Alta filter for the first time. I was a bit worried about oversaturating it (I don't think I did). I was wondering if oversaturation could cause the oily stuff on it to get sucked into the supercharger/engine? Would it do any damage if it got in there?
Old Jul 15, 2004 | 10:32 PM
Ryephile's Avatar
Ryephile
Two medium spray-coats of the UNI oil will do the trick. Msfitoy learned the hard way and used WAY too much - remember the oil is just supposed to coat the filter, not submerge it
Old Jul 16, 2004 | 09:35 AM
apexer's Avatar
apexer
It won't damage anything, just makes a mess as excess oil will drip into bottom of airfilter box and some may get coated into the intercooler. Will cost you some minor HP loss.
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
thadscottmoore
Sep 25, 2015 10:07 AM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
