R53 03 front end noise
Old Mar 23, 2014 | 12:42 PM
Husam Hammadi's Avatar
Husam Hammadi
I've been having a front end whine that gets louder with speed. It doesn't get louder with revs, and i've turned off the engine while going 20mph and the noise was still there..
Car has worn out FCABs but not that bad. My dad checked the wheel bearings by doing the 9-3 and 12-6 thing and it seemed okay.
What else could make this noise other than wheel bearings? and what better way to check it?
Thanks.
Old Mar 23, 2014 | 01:28 PM
mrbean's Avatar
mrbean
Might be tires but the 9-3, 12-6 test isn't fool proof.
One of my rear bearing went bad but was still tight as a drum with zero perceivable play. When I spun it by hand it felt like there was sand in place of the grease inside.
Old Mar 23, 2014 | 04:06 PM
ZippyNH's Avatar
ZippyNH
Rock stuck under a brake pad or in the dust shield....even a CV joint that is trashed....they have bearings....
Old Mar 29, 2014 | 07:15 AM
Husam Hammadi
deleted
Old Mar 29, 2014 | 10:16 AM
ZippyNH's Avatar
ZippyNH
Motor mounts are not a rotating sound....and be a thunk.....
Would go away as you put it in neutral when rolling...and thunk when you put in in/out of gear....
Look at the brake pads? Stuck caliper or maybe the bonding on acpad failed and a chunk is grinding away?
Does the sound govaway when you brake?
Get worse as you turn?
Still hear it if you go into neutral with the car rolling?
Gets worse as you speed up...matches ROAD SPEED? OR MATCHES ENGINE RPM.
Hear it rolling the car in neutral in a driveway out if gear? All are clues....
Old Mar 30, 2014 | 06:01 PM
Husam Hammadi
delete
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
boostedhaze
Jan 2, 2018 07:26 PM
silence2-38554
Nov 12, 2015 09:39 AM
smlzilla
Aug 14, 2015 07:00 PM
FatherG
11
Aug 7, 2015 07:49 PM
