Backup light Switch on '06 MCS
Old Dec 10, 2013 | 10:33 AM
Aaron McCracken's Avatar
Aaron McCracken
ok so i have an 06' MCS USA 6speed and my reverse lights wont come on. i have replaced both bulbs and checked fuses to no avail. this has led me to the conclusion that the switch is bad.
info on "Jezebel"
  1. 06' Mini Cooper S
  2. hardtop
  3. left hand drive
  4. 6 speed
  5. Later year Manufacture date
so can anybody provide me with pictures and/or info of -
  1. where its located
    (i know its visible behind one of the front wheels on the tranny just dont know where/which)
  2. what it looks like
  3. what tools i'll need (sizes of wrenches, etc.)
  4. what to expect (fluids leaking out, etc.)
  5. is programming needed?
I know this has been mentioned in several threads however i have yet to find a single posting with all this info on it.
thanks guys/gals i appreciate any info and pics
Old Dec 10, 2013 | 10:47 AM
minibx's Avatar
minibx
It's # 7 on the diagram
Old Dec 10, 2013 | 11:01 AM
Aaron McCracken
is this it?
Old Dec 10, 2013 | 11:09 AM
Kbron2000's Avatar
Kbron2000
info on "Jezebel"
  2. hardtop
  3. left hand drive
  4. 6 speed
Some of the European cars needs the computer to be reset by the Dealer to recognized the new lights.
Old Dec 10, 2013 | 11:10 AM
minibx's Avatar
minibx
07 23117527716 BACKUP LIGHT SWITCH 0.02 1 $17.27
Yep that should be it, I don't know if you can reach it from the FL wheel or taking the airbox out but the airbox will take longer
Check out figure # 16 on the Pelican parts article
http://www.pelicanparts.com/techarti...eplacement.htm
Old Dec 10, 2013 | 11:21 AM
Aaron McCracken
thanks gents.
this is a project im not particularly excited about tackling.
i have even considered getting some aftermarket LEDs and running a toggle up front (my model does not have fog lights so i have to open spots) and just manually turning on and off for my reverse lights. then i also have the option of freaking out tailgaters :D
Old Dec 10, 2013 | 11:28 AM
minibx's Avatar
minibx
thanks gents.
Good luck, I would just change the switch it shouldn't be that difficult with basic tools
Old Dec 10, 2013 | 11:40 AM
Aaron McCracken
i will make the attempt. thanks guys
Old Dec 10, 2013 | 12:08 PM
That's the part, here is another picture.
Back Up Light Switch # 7 in that diagram above.
http://www.ecstuning.com/Search/SiteSearch/23117527716/
Scroll to post #11 for the DIY, they jacked it up and went through the wheel well, I would recommend a solid jack stand on top of that. Not just the emergency lift.
https://www.northamericanmotoring.co...rse-light.html
Thanks and good luck.
Old Dec 10, 2013 | 01:46 PM
Aaron McCracken
ok so when i take my wheel off i can see that part, however on mine there is nothing plugged into the top of it? WTH am i supposed to do about that
Old Dec 10, 2013 | 01:50 PM
It must have been unpluged or something ? See if you can find the wire down there or maybe hanging under the airbox. Have you done work in that area before and maybe it came unpluged ?
Thanks.
Old Dec 10, 2013 | 01:54 PM
Aaron McCracken
i havnt no but i am gonna go take a look and see i cant fix it
Old Dec 10, 2013 | 02:22 PM
Aaron McCracken
here it is...i looked everywhere and found no wire
Old Dec 10, 2013 | 03:29 PM
minibx's Avatar
minibx
Ok, did the lights work before? Or you just noticed that they weren't working? Are you the original owner? Whenever you do a clutch or tranny work you have to unplug it and it's very easy to forget to plug it back in, it has to be tucked in the somewhere maybe around the AC lines or something
Old Dec 11, 2013 | 09:29 AM
Aaron McCracken
i was just recently notified that the lights weren't working. i am the 3rd owner.
i think i need to come down from the top or put it up on the lift but i agree it has to be there somewhere
Old Dec 11, 2013 | 10:02 AM
minibx's Avatar
minibx
Good, the good news is that chances are that you won't have to get a new switch, so if you didn't have any work done on it chances are that the PO did and they disconnected it and obviously forgot to plug it back in.
Yeah lifting the car should help you locating it. I hope that you find it and at Least you now know what to look for.
Good luck
Wohnson89
Jun 10, 2020 04:53 AM
emulajavi
Dec 24, 2018 09:15 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
dyeLucky
Aug 7, 2015 07:10 AM
