Brakes going bad???
Old Nov 4, 2013 | 09:41 PM
tummi_gummi's Avatar
tummi_gummi
Brakes going bad???
So a possum ran out in the road and I had to slam my brakes(65mph-stop in about 6 car lengths) funny thing was they wouldn't lock up and started to get stiffer the longer they were held down. I almost tapped the little critter! My mcs is an 02 and has 255k miles. I replaced the rear calipers with rebuilt ones from oriellys and put ebc green stuff front pads on and had ebc green stuff rear pads til one of the calipers failed and locked up and fried the pad so now I just have some 90$ rear pads from oriellys. Not sure brand or type. But they were the best they made. I also put new stainless brake hoses on. Also put slotted rotors all around (ATE brand) I picked up from wmw. All this was done about 10k miles ago. So I'm not sure why it's doing this. I didn't feel my abs when I slammed the brakes either. What gives? :(
Old Nov 4, 2013 | 10:00 PM
RobMuntean's Avatar
RobMuntean
Get rid of your ebc's...too many failures. I'm changing mine in the spring.
Old Nov 5, 2013 | 04:53 AM
yetti96's Avatar
yetti96
If they didn't lock up then the ABS was working. You didn't feel that gritty or grinding kind of pulse through the pedal?
Should be no issue with the EBC stuff, I have run the redstuff pads and liked them. Never heard of any failures, this is a first.
Old Nov 5, 2013 | 05:01 AM
tummi_gummi
Originally Posted by yetti96
If they didn't lock up then the ABS was working. You didn't feel that gritty or grinding kind of pulse through the pedal? Should be no issue with the EBC stuff, I have run the redstuff pads and liked them. Never heard of any failures, this is a first.
I haven't either everyone I have spoke to says ebc is great stuff and recommends them. And all abs cars I've driven have had a pulsating feel to the pedal when abs activates and does it's thing. Mine did nothing and the pedal just gradually got stiffer. It wasn't like most abs. I had a similar problem after doing a lot of stops at 30 mph back to back really hard while learning to drive the mini but I replaced some parts since and haven't noticed that but this was just like. There wasn't air in the lines because the pedal didn't go soft. It kinda felt like the brake booster wasn't helping after it got hot?
Old Nov 5, 2013 | 05:21 AM
RobMuntean's Avatar
RobMuntean
Look up failures. On this forum and others such as motoring alliance.
I have the greenstuff but my driving habits aren't suited for brake pads that get too hot. Lord knows what would happen when I'm driving for more than two-three hours.
I'm heading for the hawk pads.
Old Nov 5, 2013 | 05:29 AM
minsanity's Avatar
minsanity
My greenstuff rears failed a coupla weeks ago, a good 2 days before our group run. Felt so blessed. Google: EBC Wake up!
Posted here:
http://www.minitorque.com/forum/f25/...solated-37402/
Some pics:
LH side:
RH separated upon removal:
Mintex also fails:
Look for some old fashioned riveted pads.
Old Nov 5, 2013 | 05:35 AM
tummi_gummi
Originally Posted by minsanity
My greenstuff rears failed a coupla weeks ago, a good 2 days before our group run. Felt so blessed. Google: EBC Wake up! Posted here: http://www.minitorque.com/forum/f25/...solated-37402/ Some pics: LH side: RH separated upon removal: Mintex also fails: Look for some old fashioned riveted pads.
In that first picture it looks like the pad to the left was installed backwards because it has rotor wear on the backing. And if that's the case that would if put a lot if pressure on the other pad creating too much heat for it's design.
Old Nov 5, 2013 | 05:51 AM
minsanity's Avatar
minsanity
Haha, not backwards, TG. What you see is where the pads used to be glued on. Pads separated & disappeared on a scary downhill drive. Having pad gone, it was hitting the rotor, hence that shiny mark. Won't take offense.:D
In all 3 decades+ of motoring, this type of pad failure was a 1st for me. Pads are changed coz they're due, never of failure. Ignored warnings about EBC as I found em good til that happened!
Old Nov 5, 2013 | 06:38 AM
RobMuntean's Avatar
RobMuntean
Haha, not backwards, TG. What you see is where the pads used to be glued on. Pads separated & disappeared on a scary downhill drive. Having pad gone, it was hitting the rotor, hence that shiny mark. Won't take offense.:D In all 3 decades+ of motoring, this type of pad failure was a 1st for me. Pads are changed coz they're due, never of failure. Ignored warnings about EBC as I found em good til that happened!
Chad at Detroit Tuned said that the glue compound isn't that good on the EBC's.
Old Nov 5, 2013 | 06:46 AM
Helix13mini's Avatar
Helix13mini
We've been moving away from the EBC products as well. There weren't tons of failures, but enough to be annoying. We're using Hawk pads which perform better and are more durable. The only exception is the Hawk ceramic (their low dust Green Stuff equivalent) doesn't have very good brake bite.
Old Nov 5, 2013 | 07:34 AM
tummi_gummi
That's scary! Well I'll probably replace my front pads then. What's TG btw? Lol I wasn't sure if maybe a shop put that guys pads in wrong or something. Some people do drugs haha.
Old Nov 5, 2013 | 07:48 AM
minsanity's Avatar
minsanity
TG=tummi gummi
Pads are an easy task anyone can do, even those on drugs. Haha Only the blind can do that backwards, if it even fits. Haha.
Check your pads, TG & often. I've noticed other low dust pads don't bite as well as EBCs versions though. Best to be safe. Find riveted pads.
woodstudio
Mar 15, 2020 08:28 AM
sevin
Feb 1, 2016 11:30 AM
HaveATank
Sep 4, 2015 08:04 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 25, 2015 09:18 AM
