Question on Stock Airbox
Old Jul 9, 2013 | 03:51 PM
nrfitchett4's Avatar
nrfitchett4
I was poking around my engine today and noticed the connection for my stock airbox was not really connected. I'm talking about the big opening underneath the box. I can just pull it right off.
Is there a clamp or something missing? Also, the whole box is loose. It seems to only be held by one torx screw on the left side next to the pcv hose. I'll upload some pictures.
Old Jul 9, 2013 | 04:02 PM
nrfitchett4
Here are a couple of pictures.
Alternately, is there an aftermarket box that isn't crazy expensive to replace it with?
Attached Thumbnails Question on Stock Airbox-forumrunner_20130709_180223.jpg   Question on Stock Airbox-forumrunner_20130709_180232.jpg
Old Jul 9, 2013 | 05:57 PM
jordan.burks's Avatar
jordan.burks
the big opening under the box is just to let air in. the hose should run to the front of the engine capartment. mine doesnt have a clamp is just kinda clips in. it doesnt really matter if its lose it doesnt effect anything. and yes the box is only held in with one screw and then the other 3 corner just have little plastic tips that puch into place.
Old Jul 9, 2013 | 06:42 PM
05r50's Avatar
05r50
The connection is a twist lock
Old Jul 9, 2013 | 07:15 PM
nrfitchett4
ok thanks. Mine definitely isn't clip locked in place. My only concern is trashing the filter sooner from debris flying in there.
Old Jul 9, 2013 | 08:30 PM
jordan.burks
try taking your air box out and seeing if the conectors are broke. i looked at mine and 05r50 is right its a twist in. so you should be able to pust the bottome hose in and then twist it into place. the air box is really easy to take out if you want to take a look at it.
Old Jul 9, 2013 | 11:12 PM
nrfitchett4
definitely going to do that this weekend.
Old Jul 11, 2013 | 08:34 AM
+1 That bottom elbow twists in . Sometimes the people just press it together breaking the taps on the elbow or bottom box. Lift the box up a little and tip down the elbow push together and then twist the elbow up, it should then be connected. Here is a view from the bottom of the airbox when its flush connected.
#7 in diagram
Intake Manifold Tube - Short Elbow part number 13712753082
http://www.ecstuning.com/Search/SiteSearch/13712753082/
#1 is the airbox N14 Cooper S 13717577509
http://www.ecstuning.com/Search/SiteSearch/13717577509/
The whole airbox mounts right above the intake manifold. The little plastic mounting feat are located on the bottom of the box and side into rubber grommets mounts on intake manifold , they can sometimes be missing or pop out from removing the box , then the airbox does not have proper seating, is moves a bit even through there is an end screw.
Rubber Bushing Part number 11617593928 x 3 for the bottom feet of the airbox , then x 1 again for the corner screw mount ( the insert below goes into this).
http://www.ecstuning.com/Search/SiteSearch/11617593928/ES1834296/
The corner screw mount has one of those rubber bushings and also has an insert piece that the screw goes through to hold onto the manifold.
#4 in the left corner
Insert
http://www.ecstuning.com/Search/SiteSearch/13717549011/ES35182/
That covers the main mounts for the airbox.
We have the JCW Air box with tube filter if you are looking for a factory upgrade. And the fitted Pipercross JCW tube filter.
John Cooper Works Tuning Kit Intake - Air Box With Tube Filter 13720429380
http://www.ecstuning.com/Search/SiteSearch/13720429380/ES35340/
JCW Airbox lid gasket Part number 13530433064
http://www.ecstuning.com/Search/SiteSearch/13530433064/
Performance Foam Air Filter - JCW Part number PX1875
http://www.ecstuning.com/Search/SiteSearch/PX1875/
Thanks and hope that helps.
Old Jul 11, 2013 | 01:44 PM
nrfitchett4
thanks, I'm going to dive in this weekend and see if its broken or just not connected.
Old Jul 12, 2013 | 05:25 AM
Great.
Glad I could help.
Old Feb 9, 2018 | 09:56 AM
Just an update the JCW airbox is back in stock at a lower price above.
Old Jul 7, 2018 | 08:35 PM
Kehlan Krumme's Avatar
Kehlan Krumme
Thanks for this. I was hunting for those rubber bushings and could not for the life of me figure out what to look for.
Old Jul 7, 2018 | 08:36 PM
Kehlan Krumme
Are you aware of a similar airbox setup for the R60? Not an exposed pod filter, but something that integrates with the intake snorkel.
Old Jul 10, 2018 | 10:14 AM
We have the ecstuning one that integrates into that stock hose.
https://www.northamericanmotoring.co...er-intake.html
But other then that you would have to buy the whole N14 R56-R59 intake box and then use the bottom half to convert the top, like above.
Old Jul 10, 2018 | 07:24 PM
Kehlan Krumme
Ah, I see... so, just to clarify, this is doable for an R60 S with an N18 engine? Are you aware of a guide for this? I would highly interested in replacing my M7 Maxx-Flo setup if so.
Old Jul 11, 2018 | 05:20 AM
Yes,
Fits all N14 and N18 engine MINIs.
Install PDF is on the product under installation.
Here it is again.
http://bd8ba3c866c8cbc330ab-7b26c6f3..._Airbox_R2.pdf
Old Jul 22, 2018 | 12:57 PM
Kehlan Krumme
Yes,
Here it is again.
I'm having a lot of trouble fitting the lower intake hose to your carbon fiber fitting. It's seriously tight and the hose is too sturdy to squish into shape.
Old Jul 23, 2018 | 05:30 AM
Hello,
It will fit and its suppose to be tight so it will not pop out after install. Pinch both side with index finger and thumb and squeeze on the factory plastic tube. Then insert, you may need to squeeze it together more than usually needed as these are handmade carbon pieces. But it should work.
One trick is to open the hood and let the sunshine hit the factory tube or pull it out and let the factory tube get warm in the sun, some people heat it gently with a hair dry on the plastic end. Thanks and hope that helps.
Old Mar 28, 2020 | 04:08 PM
JASmith512's Avatar
JASmith512
MAJOR thank you! I'm new to owning a mini and you just saved me hours of messing around.
Attachment 156273
#7 in diagram
Insert
Old Mar 30, 2020 | 07:13 AM
Welcome, glad to help out my fellow MINI owners!
Old Dec 24, 2022 | 03:16 PM
Jeffrey Daitz's Avatar
Jeffrey Daitz
You answered two questions for me:
1.The proper intake tube fitting, and
2. I had a loose bushing that I had no idea where it came from. Now I know where it goes. Just got an excellent condition used, unbroken air box and a K & N filter. Zoom zoom! 🏁🏁
Old Dec 26, 2022 | 09:42 AM
Glad to help!
Solamar
Jul 11, 2018 10:49 AM
xbritt
May 26, 2012 05:43 PM
AggieMini11
How to
Oct 16, 2009 05:43 PM
Pizzazz
Jul 23, 2007 03:58 AM
Chitown_COOP
May 18, 2004 07:30 PM
