random cel light and safe mode at boost
Hey guys. I just got the r53 2005 6sp 63k mi. Its been hot recently and when I use the a/c I would hear a fan/coolant fluid moving noise. I rarely use my a/c but only when its above 90 and on the freeway. Recently the weather has been hot in socal, so i have been using it a lot the past 2 days.
Yesterday on the way home my car on the freeway with a/c on going at around 75, my car went limp/safe mode and the cel light came on. I pulled over, turned off a/c and stereo. Restarted car, cel still on, drove car again, but went limp again right at boost. I managed to get off the freeway without boost. On the surface streets I drove the car and it was back to normal, but cel still on. Drove it 2 miles lightly, but saw white smoke come out of the hood scoop, not a lot. Got home opened the hood, no smoke but a burning smell not rubberish, not sulfur.
Symptoms
-car still strong, will engage boost
-limp mode with cel happened a long time ago but got oil changed and mechanic said everything was good. Last time it was a hot day as well. Same symptoms
-no irregular smoke/smell from exhaust
-engine temp reads and feels normal
-no leaks/fluids on the floor
-clutch is normal
-no rattles or metal noise. Had slight diesel sound starting a couple months ago. That comes and goes randomly
-the smell was not too strong, not rubbery but not sulfury. It was maybe a fluid smell?
white cloud of smoke coming out of hood scoop
Any ideas of what the problem would be? Does any of this sound familiar?
Thanks for the help guys.
Symptoms
-clutch is normal
I have no manual. I'm confident in doing mechanical work on my car, but I just Dont have the tools. It might not be worth it be cause of that.
Braminator you are awesome! Thank you for your help!
What do you think between the PRW and ATI crank pulley? Is it worth being double the price in durability and performance? I'm assuming one is fluid and the other is not?
http://www.pelicanparts.com/techarti...eplacement.htm
IMO it is mostly in the name and popularity. They both do the same thing, so IMO I would go with the PRW. Here is a great how to
Silly question. Belt removal tool, is that super necessary? Should I upgrade my supercharger pulley while I'm at it? Or is that a lot more work?
This for the pulley remover http://www.cravenspeed.com/quick-puller/
http://www.ebay.com/itm/Mini-Cooper-Serpentine-Belt-Tool-Supercharged-/251275644900?pt=Motors_Automotive_Tools&hash=item3a81320fe4&vxp=mtr
07-16-2020 12:54 PM
Navigation & Audio Steering wheel controls for music
MES11
Navigation and Audio
08-06-2015 08:52 AM
